Old 03-26-2012, 02:22 PM   #1
1970 31' Sovereign
Burnsville , North Carolina
"J" Hinge strips
Hi Guys,
I want to replace the "J" Hinge strips on two of the access doors on my "70 Sovereign. Does anybody know if this material is available? If not, any suggestions for another way to fix these? Thanks, Bill
Name:	J Hinge.jpg
CeloNC is offline   Reply With Quote
Old 03-26-2012, 04:02 PM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
the J hinges on my 73 and the hinges on my 69 are not the same. I don't know what the 70 would have since I have seen that the 70 has parts from the 69 and parts from the 70's. AS used parts til they ran out so it could be from either years. 69 was a transitional year (they call it the bastard year) It is different from the others. (last year airstream made the trailer and the first of the body style)
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 03-27-2012, 07:17 AM   #3
1970 31' Sovereign
So, do you know where this material might be available? Thanks, Bill
Old 03-27-2012, 08:02 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Out of Doors Mart sells the window J hinge:
Window Hinge 1969 to 95 195297-05 [195297-05] - $2.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Might be worth buying a length of it and see if it will work on the hatch.
Chris
Old 03-27-2012, 08:55 AM   #5
Originally Posted by CeloNC View Post
Hi Guys,
Many owners remove the hinge on the door, then invert the door, and install a piano hinge at the bottom.
Then, the door will never be on the ground again, and it's out of your way when you reach into that compartment.
A cheap fix, and very effective.
15" Tire dilemma 91Excella Tires 13 09-14-2012 09:31 PM
A few 'details' taken care of... ROBERT CROSS Clearcoat, Exterior Paint & Trim 32 06-09-2012 04:38 AM
The "95" Question monkeypants On The Road... 2 03-28-2012 05:11 PM
Vintage 1968 "overlander" airstream-28' eBay Watch Airstreams on eBay 0 03-23-2012 08:40 AM
Getting Safari 'off the ground' for new axle. SafariFaye Axles 9 03-18-2012 04:16 PM
