Old 01-29-2013, 07:50 PM   #1
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
It rained!
Finally. Nothing like an inch and a half of rain to help me locate the leaking windows... But the good news is there aren't any other leaks except the one by the door that I was already aware of.
New window seal and door gaskets will be the next purchase and project.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 02-03-2013, 03:05 PM   #2
eljay's Avatar
1968 24' Tradewind
Warm enough to get out and poke around. The front top portside window definitely has a problem. I picked and scaled a bunch of silicone, vulkem and rtv out of these corners and frame. The dirt and algae tells me this has been a problem for a while...
ID:	178083   Click image for larger version
Eljay
Old 02-03-2013, 03:07 PM   #3
eljay's Avatar
1968 24' Tradewind
Other pics of the top. Missing vulkem in most seams.
ID:	178086   Click image for larger version
Eljay
Old 02-03-2013, 08:09 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
If you're going to polish that, I'd strip it, power-wash it, polish it, and then seal the seams. Otherwise you get to do much of it all over again. Just sayin' . . .
Old 02-04-2013, 05:20 AM   #5
eljay's Avatar
1968 24' Tradewind
I have a friend who wants to polish it but that's not on the immediate agenda. I have a "usable by June" goal date. Thanks for the advice but I'll probably have to seal the seams twice.
Eljay
Old 02-04-2013, 06:28 AM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
FYI, I found that after you pull all the old gaskets off the window frame the best way to remove the old adhesive is to use scotchbrite buffs on a dremel tool. The little buffs are pricey but worth it in time saving and not having to mess with solvents. I tried solvents and scraping but the dremel produced the fastest and best results. The area that is scoured by the buff will be covered by the new gaskets.
Glad your TW only had a couple of leaks, mine was leaking like a sieve when I found it.
Love my 68!!
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 02-07-2013, 09:30 AM   #7
eljay's Avatar
1968 24' Tradewind
More Rain!
Heard the thunder in the middle of the night and smiled. Another chance to check out my window repairs. The drought will be over if I keep going at this rate.
I was successful on stopping the big leak in the upper port window. No rain running on the inside of the pane. Less water movement in the corners but still damp so I will work on those again.
Got notice from Vintage Trailer Supply that my order(s) have been shipped. That's the seal material plus some other items.
Eljay
Old 02-07-2013, 09:35 AM   #8
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Now that you mentioned gaskets eljay, did you ever find a source for your door gaskets? I need to replace mine and also not real sure about what to stick it in place with.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-07-2013, 11:51 AM   #9
eljay's Avatar
1968 24' Tradewind
I will order 16 feet of D door gasket from Inland RV. I will use 3M Super weatherstrip and gasket adhesive for all of my applications.
Eljay
Old 02-09-2013, 06:16 PM   #10
eljay's Avatar
1968 24' Tradewind
More rain!
I have made a lot of progress on the window leaks. Got around all of the fixed/frame windows with minimal leakage at the corners. Will work from the inside now when they are dry again.
I'm enjoying the rain. Amazed at the quantity of snow I see pictured in the posts from the northeast.
Got notice that FedEx is delayed shipping my items from Vintage Trailer Supply due to weather. I think that's plausible.
Eljay
Old 02-09-2013, 08:27 PM   #11
Central , Mississippi
I guess I'm lucky...
Despite all of the hype I've never had a bad window gasket cause a water leak into the camper. The design seems to shed water back outside unless I'm towing in the rain. It's a rare case where even that leaks.
All of my leaks have been bad joints and the cure has been redoing them. My '63 still has most of the original gaskets, my'91 is all original.
Sure, I'm gonna redo them but it seems to me it's more of a hard sales pitch to focus on them as a major issue that causes floor rot.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-11-2013, 05:15 PM   #12
eljay's Avatar
1968 24' Tradewind
We tackled the window by the door today. Pulled some kind of goo, maybe RTV, from every nook and cranny, rivet and even smooth surfaces. Replaced one of the Phillips latches with a good one. Got the window to pull in pretty well. The gaskets are really dry so will be replaced. I taped it until I get the seal material in.
Also got keys for the compartments. If anyone needs this knowledge: in 1968 the compartments all took Chesler 1405 locks. Same keys for all. Airstream Trailers Key Chart
I accessed one from under the double bed. Removed the screw and carefully removed the tumbler without compressing or altering any of the pins. Then I removed the compartment door. Took that whole assembly to the nearest locksmith (45 miles away) and received new keys that work in all of the compartment locks I have. I'm happy.
Eljay
Old 02-21-2013, 09:13 AM   #13
eljay's Avatar
1968 24' Tradewind
This is the inch of snow predicted. Thunder snow and lightning. And it's still coming down. Guess my AS to do list will be reading forum and shopping for needed AS items.
ID:	179474   Click image for larger version
Eljay
Old 02-27-2013, 08:54 PM   #14
eljay's Avatar
1968 24' Tradewind
12 more inches of snow have kept me busy shoveling snow. Man o man I ache all over! Got the window and vent seal material in, bought more Vulkem/trempro. Ready for nicer weather.
ID:	179961   Click image for larger version
Eljay
