03-20-2019, 10:13 PM
2014 27' FB International
Sanford
, North Carolina
Is this how it should look?
The attached photo shows the lower of the two door hinges on our FB 27 International. We noticed recently that the pin may be extruding. The upper hinge is flat across the top. Is this indeed the pin working its way upwards or a normal situation? If not normal, should we gently pound it back in? Any help is much appreciated
Jon and Sharon
03-20-2019, 10:20 PM
2002 25' Safari
Dewey
My 75 had a hinge that would do that. I would tap it back in from time to time. I cleaned the top of the shaft once and applied some epoxy and it never came out again. Be careful taping that back.
Richard
03-20-2019, 10:27 PM
Sanford
, North Carolina
Thanks much for your rely/help. Trying to attach picture as .pdf.
03-20-2019, 10:31 PM
2017 30' International
Broomfield
Definitely should not look like that.... that pin should be flush. Agree that you should carefully tap it back in.
03-21-2019, 09:40 AM
Watertown
, Massachusetts
We had that problem. Turns out there was a "C" ring washer missing. It fits into a little groove in the pin and prevents this.
03-21-2019, 09:57 AM
Oswego
I'm not sure what year they started using the grooved pin with an "e" clip retainer. I know it was well after 2007. If your pin doesn't have the groove, the newer pins can be ordered. One of mine backed out and I replaced with updated pin. Other one hasn't backed out, but the new pin is in my parts kit, just waiting.
-Rich-
03-21-2019, 09:59 AM
Oswego
Since I dont see that the pin was ever staked in place, I'd bet you have the new pin and the e-clip has fallen out, as suggested above.
-Rich-
03-21-2019, 10:22 AM
S/O#080
2006 30' Classic S/O
Naples
Jon and Sharon
My 2006 Classic had no C clip. Pin worked it’s way up out of groove regularly. Replaced with C clip pin and since October when replaced have had no problem. Good luck! Tschupps
03-21-2019, 04:54 PM
Sanford
, North Carolina
Thanks to all who helped. With gentle pounding it went right back down. Plan to watch it and buy the C-clip pin if it works its way out again since we are on the road.
03-21-2019, 05:53 PM
2008 28' Safari SE
Highlands
, North Carolina
This you tube link will guide you through the replacement process:
https://youtu.be/k8AjMK-simk
03-21-2019, 10:13 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
As mentioned there is an update on the pins. Since I updated mine some time ago the are staying put.
guskmg
03-22-2019, 07:48 AM
2006 28' International CCD
Saint Paul
Had same problem, "C" clip washer was solution. "Parts" dept at JC will ship necessary items to you with some persuasion, or from the store. Sometimes they insist on sending it to a local dealer. Inconvenient.
03-31-2019, 12:53 PM
2016 25' Flying Cloud
Houston
I was having the same problem on my 2016 FC FBT. The top hinge pin would work its way up. I kept tapping in back in. When I was at service center in Jackson Center for other work I asked them to look at it. They said it needed a keeper pin. Since they fixed it no problems.
03-31-2019, 04:28 PM
2017 27' International
Galt
protruding hinge pin
I had the same issue with our 2001 Excella. I ended up drilling and tapping a small hole in the knuckle, and putting in a set screw. That finally cured the problem
Andrew K6STN
2017 27'FB International
2017 F-250 4x4 diesel crew cab Lariat
04-01-2019, 04:55 AM
2010 27' FB Classic
Austin
The hinge on my 2010 27FB was doing this. I tapped it down and used a center punch to slightly peen the top. It slowed the process down enough to live with.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
