It is not a film...it's frosted glass. Ours is the same way. I've thought about this off and on as well. You could no doubt have the glass replaced at some expense... But a couple of things to consider are: (1) if the window is clear you'd probably want a curtain on it ...which would have to go between the screen door and the door... and then, (2) when the screen is closed and the door is open, the curtain would be exposed to the elements. I suppose you could put a tension rod cafe curtain affair inside the frame of the window, but my guess is that it'd be more hassle that it's worth...and you'd probably have it closed more often than you have it open. I'd be interested to know what you come up with.
(We had a small motor home that had a clear glass window in the door...with a curtain. It seemed like the curtain was always dirty and seemed to catch every bit of dust around...it was a constant hassle.)
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
