Old 08-17-2015, 06:37 AM   #1
2013 23' International
foster , Kentucky
Cool International Window Gasket Coming Loose
Our trailer is only a few years old and babied. In other words when not in use it is kept in our Morton Building. We finally found a spot we are going to use on a semi-permanent basis. Entered the camper only to find that the screen was coming out and part of the gasket was out of its place ...is this repairable? If yes, how? Or is this something that has to be replaced entirely? Any words of wisdom would be much appreciated.
Thanks!
kfthomas is offline   Reply With Quote
Old 08-17-2015, 07:39 AM   #2
Thanks!
The screen "spline" some what shrinks in time.
It's most likely to pop out at the corners, if at all.
Simply reinstall it, making sure that it is pushed down as far as possible in the channel.
Old 08-18-2015, 06:53 AM   #3
foster , Kentucky
Thumbs up Thanks Andy
I tried that ...but I was concerned that was not the right thing to do So I didn't "force it" ...I will try with a little more "oomph". Thanks!
My Entry Door Hinges Are coming Loose SaabLover Exterior Storage Compartments & Access Doors 18 08-05-2012 05:07 PM
Trim rail on '73 Ambassador coming loose Trailobite Ribs, Skins & Rivets 2 07-06-2011 05:46 PM
dinette bench keeps coming loose DaCosta Cabinets, Counter Tops & Furnishings 10 07-11-2010 09:25 AM
2004 Classic Trim coming loose IrishRover2 General Repair Forum 6 03-28-2008 06:06 PM
"A" in Airstream is coming loose.... Kistler Clearcoat, Exterior Paint & Trim 8 06-09-2007 10:34 AM
