Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 07-28-2018, 05:15 PM   #1
1974 21' Globetrotter
Priest Lake , Idaho
Interior window frame (sink) question
Does anyone know what these slots are for? I attached a picture. I would like to be able to lock my window open on the lowest setting and was wondering if anyone has done that and used these slots. It just gets so hot in my little metal box during the day while I'm at work.
carmangel is offline   Reply With Quote
Old 07-28-2018, 10:35 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yep! My '73 Globetrotter had the same slots. There is a roll-down blind that mounts at the top of that plastic window frame, and the slots provide places for the roll down shade to latch into so that you can vary the amount of light/visibility at that window.
There should be some plastic slotty things that are on a much smaller scale, that mount directly to the metal interior frame of the window. Look at your other windows, as they may be hidden by the interior plastic frame on this window. These are the things that you will use to hold your windows open at various levels, using those chromed knobs that are on the rods that lift the window outward. The original ones were probably white, and tend to get brittle and break. You can still buy new versions of these that are black.
good luck!
Old 07-29-2018, 02:42 PM   #3
Priest Lake , Idaho
Thank you! I got my Airstream used and I guess it was missing the roll down shade. However, mystery solved! So, thanks!
Replacing 2014 27FB sink with vessel sink Wishing Sinks, Showers & Toilets 15 08-30-2018 07:05 AM
2014 Sprinter kitchen sink faucet loose from sink base AirHammar Plumbing - Systems & Fixtures 0 11-15-2016 11:11 AM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
Screen window insert for rear/sink window? MaineStreamer 2005 - 2010 Safari 0 08-02-2015 11:09 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
