Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 08-21-2009, 07:14 PM   #1
AudioMike's Avatar
Profile:  1966 22' Safari
Littleton , Colorado
Installing Glass in 68' type 3 hinge
I am replacing the rear bathroom glass in a 68' type 3 - 2 part hinge. I have the glass and the hinge is in two halves. I need to know whether a "tape" or some sort of silicone is used to sandwich the 2 pieces together. If someone has a graphic for this hinge it would also be appreciated.
AudioMike is offline   Reply With Quote
Old 08-21-2009, 09:13 PM   #2
BIGED52's Avatar
Profile:  1967 22' Safari
MILAN , Illinois
Glass installation
AudioMike, Butyl tape available at most glass shops. They may sell by the foot or by the roll so be prepared. The tape wraps over the top edge of the glass and then clamp is screwed back to the hinge to hold the glass in tight. Andy R. from InlandRV recommends doublefaced reinforced tape between the glass and tape. Once clamped back together you can trim any excess tape or butyl tape at a angle from the hinge edge outside of the window and even with the clamp edge inside the trailer. Hope this helps. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-21-2009, 09:58 PM   #3
AudioMike's Avatar
Thanks Ed,
Is there a preference for either Butyl or doubled sided tape? Not sure if there is an advantage one over the other.
Old 08-21-2009, 10:01 PM   #4
Stefrobrts's Avatar
Profile:  1968 17' Caravel
. , Washington
When I did the corning kitchen window on my 68 I went to the local glass shop and they gave me enough double stick window tape to do the job, they had enough remnants laying around from other jobs, they just gave it to me. It was a thick, spongy tape, and sticky as all get out. Once it was down it was down for good.
Stephanie
Stefrobrts is online now   Reply With Quote
Old 08-21-2009, 10:27 PM   #5
BIGED52's Avatar
MILAN , Illinois
Glass tape vs butyl tape
Mike, Stephanie is right too! The butyl tape from the glass shop is all I used and I had to replace all my glass. PO had all plexiglas (no original corning glass at all was left) except the non-opening glass on the window to the right of the entry door. The tape I got has a peel off backing on one side the other side was protected by the roll. The double sided reinforced tape was recommended to help hold the butyl tape in by Andy as an extra precaution against the glass falling out of the hinge/clamp assembly. I have had no trouble with this but I have read about others who stated that glass/butyl tape tended to slide out of the clamp/hinge. My tape from the glass shop was very sticky as Stephanie says. It holds very well in the clamp/hnge. Show the shop your clamp and tell them how the glass mounts between it and the hinge plate. They will be able to set you up with the best tape to hold the glass in. You may get lucky like Stephanie did and find them able to just give you enough to do the job. I wasn't that lucky but then I had a lot of glass to install. Hope this helps. Happy Trails, Ed
AIR#7110
Burma Shave
Old 08-22-2009, 10:30 AM   #6
centennialman's Avatar
Centennial , Colorado
Mike,
There are graphics on the website for Vintage Trailer Supply. Give that a try....if that doesn't work, you can take a look at mine if that will help you out.
Steve "Centennial Man"
1966 Airstream Safari - Her name is "Aunt Bee"
centennialman is offline   Reply With Quote
Old 08-22-2009, 02:20 PM   #7
Profile:  1968 24' Tradewind
Oxford, , Mississippi
I just replaced all the curved windows in my 68 Trade Wind. I used double sided foam tape from Home Depot. Butyl will work, but I felt like the tape would hold a little better. Either way should be fine.
[IMG] code is Off
1968 Type 3 window hinge not separating air-austin Windows & Screens 7 10-25-2008 10:25 PM
(Inland RV) Installing new rear glass, 67' overlander questions bvanetten 1967 Overlander 13 08-03-2008 11:51 AM
Corning Glass window trim - Had any luck installing? Coloradobus Windows & Screens 0 07-17-2004 04:32 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 08:20 PM
What type of glass should be used on a 60s AS windows? Andy R Windows & Screens 1 06-19-2002 10:23 AM
