Old 05-19-2014, 12:01 AM   #1
Inside Door Handle
Can anyone suggest a replacement for a Safari 67 inside handle of the main door? The lock is in perfect order except that the inside door handle broke.
I believe that lock is a Chesler lock. The inside of the broken handle reads
"47 T6"
Many thanks,
Rupert
RupertJ is offline   Reply With Quote
Old 05-28-2014, 09:39 PM   #2
Try Out Of Doors Mart.
PatCoates is offline   Reply With Quote
Old 04-24-2015, 08:58 AM   #3
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by RupertJ View Post
Can anyone suggest a replacement for a Safari 67 inside handle of the main door? The lock is in perfect order except that the inside door handle broke. I believe that lock is a Chesler lock. The inside of the broken handle reads "47 T6" Many thanks, Rupert
Hello
Did you find an inner handle?
Can you post pictures of what you have?
I have a Chesler lock also missing the inner handle, I figured out the bargmann L100 or L200 fits and functions perfectly.
Mike
desertair27 is offline   Reply With Quote
Door handle for outside of screen door RTurnConn Exterior Storage Compartments & Access Doors 1 08-27-2011 09:16 PM
Help needed with inside door handle 2goldens Doors & Locks 2 07-24-2011 07:59 PM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
$60 to make key for lock inside handle SafeHarbor 1978- 1979 Excella 500 0 04-17-2006 06:30 PM
Inside door handle for a 1984 International Bennie 1980-1984 International 0 08-06-2002 08:37 PM
