Old 10-19-2012, 06:20 PM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Idiot question on window gasket replacement
78 Tradewinds with the double pane windows.
OK, I'm getting ready to replace the old double flared gasket with the new "D" gasket.
Does the "D" gasket glue to the same surface on the window frame as the old gasket? It looks like it would be a "slide together" closure that way, rather than a "compression" closure. The compression sounds like it would work better.
Thanks!
Old 10-19-2012, 06:42 PM   #2
1981 31' Excella II
New Market , Alabama
The flat part goes on the window frame and it should compress it when the window is closed. So yes the same surface should be glued. The round part faces the frame on the trailer.
Perry
Old 10-19-2012, 06:45 PM   #3
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
I thought you had "D" gasket on the side windows and double-flared on the fore and aft windows in 1978, but perhaps I'm mistaken.
Can you by any chance provide photos?
Unless I am confused by the terminology, there is nothing new about "D" gasket.
But, as my wife would be the first to point out, I am easily confused.
Ken L
2019 Flying Cloud 27FB
2018 GMC Yukon Denali XL
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-19-2012, 07:32 PM   #4
funkill's Avatar
Tucson , AZ
Images: 27
I'm almost finished with this job on my 1973 Overlander. Was provided D gasket from Inland RV for all windows & compartments. Larger size too - must be for the door. After removing the old gasket, I applied the D to the same surface. It is a tiny bit wider than the original and it extends a bit past the frame surface. I removed the peel-off paper to expose the adhesive and added the 3M gasket material to both the D gasket and to the window frame until tacky. Then added a bit more to the window side to *reactivate* the 3M adhesive. Took me a couple times to get in the swing but then it went quickly. Remember to position the end/splice centered at the bottom of the window.
Laura
funkill is offline   Reply With Quote
