Old 11-03-2016, 02:10 PM   #1
2013 16' Sport
Boulder , Colorado
How would you fix this?
The cylindrical rubber gaskets are pulling out of the corners of my windows in my 16' Bambi Sport. Assuming I can stretch them back in, any advice on how to keep them in place? Photo enclosed.
Seecue is offline   Reply With Quote
Old 11-03-2016, 02:41 PM   #2
2016 28' International
San Marcos , California
I would try auto glass adhesive.
Clean out any dirt, lay a thin bead and then use blue painters tape to hold the strip until it sets.
Mgieselman is offline   Reply With Quote
Old 11-03-2016, 02:49 PM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Can you re-bed them?
You will likely not obtain much service for your fix.
sgschwend is offline   Reply With Quote
Old 11-03-2016, 02:56 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
The material that has pulled away is normally used to hold window screen material in place. It is held in place by friction. Do not glue or caulk it in place. (google screen spline, available at any hardware store) This material shrinks as it ages, so that is why it pulls away at the corners.
There are three options to make a lasting repair.
1. Rip it all out and reinstall if it's not too brittle.
2. Rip it all out and replace it with new.
3. Cut the material near the corner and tuck it back in. It does not have to be continuous to do its job.
add edit:
If you decide to buy new take a piece of the old with you. It comes an a few different diameters.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 11-03-2016, 04:22 PM   #5
2019 27' Globetrotter
Missouri Valley , Iowa
X2 on what A W Warn said. I've replaced the spline holding the window screens and the window protectors. It is not a bad job with the right size spline and, usually, a spline tool to roll in the new product.
Dan
Farmer Dan is online now   Reply With Quote
Old 11-03-2016, 04:29 PM   #6
2013 16' Sport
Boulder , Colorado
Thanks a million! It has decent elasticity left, so I am going to cut and tuck. Wonderful solution.
cq
Old 11-07-2016, 10:40 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Mine is like that, too.
It's like the spline material has shrunk and there is no longer enough of it to stretch the entire length.
I am considering cutting it somewhere near the middle and pushing the corner back in. Maybe I can cut it one time along the bottom edge.
Or... Maybe I could rip it all out and put in new spline material leaving it a little too long at first to compensate for shrinkage later on.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Would you chance it? What would happen? Becky B. Repairing/Replacing Floor &/or Frame 6 03-05-2010 09:06 PM
how would you fix this? Becky B. Ribs, Skins & Rivets 12 08-28-2007 10:35 AM
How would you fix me? soldiermedic Cabinets, Counter Tops & Furnishings 17 11-02-2006 07:21 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
What would you fix first.... froggies General Motorhome Topics 13 08-15-2004 11:09 AM
