Old 10-28-2018, 09:56 PM   #1
1976 27' Overlander
Milwaukie , Oregon
How to replace door seal on a 76 Overlander?
Hey guys. I have a 76 Overlander and am overhauling the door. I知 looking to install the replacement gasket from Vintage RV. I知 seeing photos and websites showing installation in a variety of areas, ranging from the lip edge of the door, nestled in the angle of the lip and body of the door, or even directly applied to the Airstream body itself.
What is the proper install location for this?
Also, I知 reading people say not to use the stick-on adhesive and to instead do a dedicated adhesive specifically for seals. Anyone has a link to the right part for this?
Thanks!
JoleneAS is offline   Reply With Quote
Old 10-29-2018, 06:24 AM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I used the stick on adhesive that came with the VTS gasket and it worked great. Mine is installed on the lip of the door, as close to the edge as possible without overlapping. If you put it too close to the angle of the lip, it won't be thick enough where it meets the door frame to form a seal.
TheGreatleys is offline   Reply With Quote
Old 10-29-2018, 12:13 PM   #3
1976 27' Overlander
Milwaukie , Oregon
Thanks so much for your reply! Was looking at your Airstream blog and yours looks amazing. Great work!
I'm curious, do you have any photos of the door seal that I could use for inspiration?
Old 10-29-2018, 12:31 PM   #4
1974 27' Overlander
It's not really much to look at but here's what it looks like installed. The line visible in the middle of the gasket is the indentation made by the door frame where it seals.Click image for larger version
Old 10-29-2018, 12:59 PM   #5
1976 27' Overlander
Milwaukie , Oregon
Thank you so much. Does this look like the stuff you used? http://odmrv.com/catalog/index.php?m...roducts_id=338
Also, I'm curious about how you addressed the latch area. I feel like I'm going to need to modify the seal to make the latch work out.
Old 10-29-2018, 03:43 PM   #6
1974 27' Overlander
Yes, that looks like the exact stuff. I got mine from VTS, but that's what it looked like.
I notched out the area to accommodate the latch. Remind me later if you need a photo and I forget to post one, and I'll snap a picture.
Old 10-29-2018, 04:04 PM   #7
1976 27' Overlander
Milwaukie , Oregon
Heck yeah, would love to see a photo of how you notched it out. Thank you so much!
Old 10-29-2018, 04:06 PM   #8
1974 27' Overlander
Originally Posted by joleneas View Post
heck yeah, would love to see a photo of how you notched it out. Thank you so much!
Old 10-29-2018, 06:39 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks joleneas and t greatleys. I need to replace my 75 Overlander door seal this winter and now I know much more about it.
First I need to straighten the door to the opening. I appears it blew open sometime in its life. I've read about how to straighten a door.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Sheared rivets on door frame, replace or seal over? EllaAir Doors & Locks 3 06-08-2015 08:34 AM
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
