Old 08-30-2015, 12:41 PM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
How the heck do you remove the round retaining clips to remove the windows??
I have a 71 Safari and need to remove the windows to strip the gaskets and install new. The windows are locked in place with round retaining rings that are about 3/16 in diameter. How the heck are they removed. They do not have slots like regular retaining rings so they can be expanded and removed. They are more like clips that look like small washers.
bvcg1 is offline   Reply With Quote
Old 08-30-2015, 01:39 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Those rings are pesky. It is possible you will not be able to resuse them. To reinstall you can drill a hole through the shaft and put in a cotter pin.
Old 08-30-2015, 02:57 PM   #3
To try and save the old washers, is a waste of time.
Since the arms will be removed, a very nice way to fix the issue, takes a little time, but is a "first class" fix.
Thread the window end of the window lift arm, and then install a "[B]nylon insert nut"[B/] on it to hold the lift arm into the window bracket.
Granted, cotter pins work, but they don't to much for looks, especially when they are in plain sight.
Plastic Retaining strap RVDreamer Fresh Water Systems 3 02-02-2015 09:44 PM
How to remove the rusty clips from glass steverad Windows & Screens 1 05-13-2010 02:27 PM
The Wheels Go Round and Round wheel interested Our Community 36 11-05-2008 04:59 PM
Round and Round She Goes thecatsandi On The Road... 21 04-03-2007 04:36 PM
screen door retaining latch 77 R GO C MH Doors & Locks 1 05-12-2005 01:33 PM
