Old 03-29-2012, 09:53 AM   #1
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
how often could this happen?
The other day I was working on the 76 Caravanner when I needed a tool box from inside the 74 Ambassador. I grabbed the key ring and unlocked the 74 to get the tool box. Later when I finished working on the Caravanner I closed the door and began to lock it however the keys were nowhere to be found. After several minutes of searching and a few choice words I concluded that the keys would show up somewhere eventually. THEY DID! I put the tools back in the 74 and shut the door and there were the keys (76) still in the door! Needless to say I felt silly. After some expirementation I find I can use either of the keys in either door. When holding the keys together they are similar but not exactly alike but both keys will unlock both doors.
bimpy is offline   Reply With Quote
Old 03-29-2012, 09:56 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
With off the shelf lock sets there are only so many key combinations. Had to happen sometime to someone.
MICHAEL
Old 03-29-2012, 10:41 AM   #3
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I can't wait to show this to my locksmith husband-- that's cool!
Skatiero is offline   Reply With Quote
Old 03-29-2012, 10:57 AM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The key to our '74 will fit about a third of the Airstreams that come into the shop.
Old 03-29-2012, 11:00 AM   #5
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
The key to the water fill started my daughters 66 Mustang. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-29-2012, 11:01 AM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The key to my uncle's 5th wheel sob fits my 67 Safari perfectly. I hear there are only 5 different keys for all trailers.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 03-29-2012, 11:08 AM   #7
Kevin245's Avatar
This doesn't happen with regularity but it isn't unheard of. I remember having a Ford key that fit my truck and car. Both were from the 70's era which were pre-chip keys. The truck key fit the car ignition, but the car key would not fit the truck.
The lock on our 76 is so worn I could probably open it with a key blank.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 03-29-2012, 11:12 AM   #8
1981 31' Excella II
New Market , Alabama
The ignition on my truck is so worn out that just about any key will start it.
Perry
Old 03-29-2012, 12:05 PM   #9
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
This reminds me, when I was a kid I used to lock and unlock my Dad's 67 Nova with small twigs from the yard.
Old 04-05-2012, 06:44 AM   #10
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We replaced the lock on our back door (under-bed storage) and noticed that the key is identical. Didn't even need to replace the one on our rings. I have no idea if they're all the same or if there's only a few combinations.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Mid way through interior vinyl removal - how to remove remnants and cross-hatch? mikeandnora Upholstery, Blinds, Walls & Interior Finishes 24 07-12-2012 09:12 PM
ST235/80R16 - does this fit? tvanwave Tires 13 03-30-2012 07:54 PM
pardon me if this is a basic question... mack-in-nc Towing, Tow Vehicles & Hitches 18 03-29-2012 11:09 AM
Is this a 1963?!! smallville 1961 - 1963 Bambi 28 03-28-2012 07:37 PM
how much upholstery fabric for a Bambi II trailer AWCHIEF Upholstery, Blinds, Walls & Interior Finishes 0 03-28-2012 01:51 PM
