Old 08-06-2018, 04:50 AM   #15
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
H20 lock
Hi,
I have a right hand H20 lock if you are interested. I sent you a message.
You can email me direct at r_whiten@hotmail.com
All the best,
Rick
montanablue is offline   Reply With Quote
Old 11-21-2018, 10:19 PM   #16
Love trip's Avatar
1956 16' Bubble
Redmond , Oregon
Bargman H20 will not lock
I have a 56 Bubble with a h20 bargman handle. The set works great aside from locking. Looks to be the original old key that fits in cylinder perfect but the key will not turn in either direction. Therefore, won’t lock. Curious if someone might know why the key won’t turn.
Thanks.
Love trip is offline   Reply With Quote
Old 11-22-2018, 06:21 AM   #17
1966 22' Safari
Fredericksburg , Texas
Thanks.
The H-20 is not that difficult of a mechanism. But, all facets of the lockset have to work correctly. In your case, it seems to be either the cylinder or the bushing where the lock cylinder square stem fits into. Some had a small panel on the inside of the door that could be removed to access the lockset. If that’s the case, you may want to remove the lockset and housing to access all the components. There could be several possibilities so it’s hard to say. Could even be a broken spring inside the housing that has jambed the works. There’s only one primary spring inside the housing that is available if broken. When time allows, maybe looks at the video on this thread. That may give you some ideas. Also, you can purchase a new lock cylinder from VTS that will work the exterior locking function, just not the interior. Good luck and let me know what you found.
Bubba L is offline   Reply With Quote
Old 04-11-2019, 08:37 PM   #18
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Originally Posted by Bubba L View Post
The H-20 is a well built lock but will only work correctly when the bushing, where the square lock cylinder tail piece fits, is in the right position. From what i’ve Found on mine is this; insert the key at the 12:00 o’clock position, turn the key to the 3:00 o’clock position to lock (turn the key back to the 12:00 o’clock position to allow the inside of the trailer mechanisms to operate), turn the key to the 9:00 o’clock position to unlock the door. Always return the bushing to the same 12:00 o’clock position to allow for inside and outside functions to operate as designed. I know this sounds a bit weird, but it’s really simple. From what I understand, the original key lock cylinder came from a 1948 Ford Mercury. That wouldn’t surprise me since a lot of various Ford parts were used way back then.
If you want to discuss, PM me and I will give you my contact info. Good luck, Bubba
I finally got to look at my lock set. I need a new main spring and lock. Other than that using your post as a guide everything works like it should. The one thing I noticed was your inside open and close handle is in a different position than mine. Mine is attached directly to the out side handle and yours is attached to something lower in the casing.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 04-11-2019, 09:25 PM   #19
1966 22' Safari
Thanks Terry. Now I won’t sleep until I get this figured out. Off hand, I don’t know why the difference. I’ll look into it. While yours is out of the door, can you send me a picture of the insides? I want to compare. Intriguing. Thanks
Old 04-12-2019, 06:59 AM   #20
1956 22' Caravanner
Originally Posted by bubba l View Post
thanks terry. Now i won’t sleep until i get this figured out. Off hand, i don’t know why the difference. I’ll look into it. While yours is out of the door, can you send me a picture of the insides? I want to compare. Intriguing. Thanks
Old 05-12-2019, 08:14 AM   #21
1997 25' Safari
1973 25' Tradewind
If anybody is looking for a H2O lock I have 3 now. I blieve they are right hand. I also have just got in 3 NOS H2O lock cylinders.
Old 05-12-2019, 08:46 AM   #22
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Terry the layout of your assembly is the same as one of mine for the main components. I believe your spring on the left is broken and your missing the top "cam". Maybe a PO modified to try and overcome missing/broken parts?
Name:	H20 Lock pic 4.jpg
Out of curiosity is there an earlier version of the H20-2; H20-1 or H20
I googled, but got nothing definitive.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 05-12-2019, 08:56 AM   #23
57Vintage's Avatar
1958 26' Overlander
Images: 21
Forgot to add, the interior door handle is on the outside of the cam and shaft you're missing.
Name:	H 20 Interior.jpg
Harold & Rebecca
Our thread:
Old 05-13-2019, 05:53 AM   #24
1956 22' Caravanner
Attachment 340511
Interesting to see that your Bargman is mounted on the outside of the door, where as mine and Bubbas is inside the door.
Old 05-13-2019, 08:00 AM   #25
57Vintage's Avatar
1958 26' Overlander
Images: 21
Photo isn't of mine. My trailer has a newer model at the moment, I just haven't tackled rebuilding the door yet.
Harold & Rebecca
Our thread:
Barman H20-0 parts needed please! desertair27 Doors & Locks 5 01-02-2013 07:18 PM
Fresh H20 mystery fill 3Ms75Argosy Fresh Water Systems 13 12-14-2007 07:28 AM
H20 heater: drain how often? TomW Water Heaters, Filters & Pumps 14 10-10-2004 10:22 PM
h20 compresser lubricant Flyincloud Water Heaters, Filters & Pumps 3 08-23-2004 06:25 AM
Filling H20 Tank via Hooked-up Hose Mike76251 Fresh Water Systems 9 03-20-2004 07:39 PM
