Old 08-26-2013, 05:29 PM   #15
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
For future readers.... Transmitted flexing showing up as missing rivets above the main entry door can flag a whole list of possible causes needing checking...
On old trailers a peek at outriggers and their through-bolt fasteners would be warranted when pop-rivets go missing and/or oxide black rings appear around them.
With the banana wrap system it too easy for previous owners to replace the cover sheet and leave chaos nicely covered up from accidents or blowouts.
My '73 trailer had sixish missing pop-rivets and same number with black rings, and we found busted/torn/un-welded outriggers plus C-channel bolts loose from rotten plywood and rusted/missing bolts. Just saying 'cuss it needs to be said
Old 08-27-2013, 01:06 AM   #16
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Hey thanks everyone for your input. I thought the sway bars were probably over kill but, that's what came with it so, what should I do?
By the way I believe the sway bars are rated at 800lbs. Did I mention I was going to Yellowstone? Maybe I'll stay home .....
By the way do any of you work .... I'm glad you're there!
Thanks, Mark
Markj55 is offline   Reply With Quote
Old 08-27-2013, 04:13 AM   #17
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Mark,
800lb tapered bars should work with your trailer. A trip to the CAT scales will tell the story.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
