Old 08-01-2013, 04:36 PM   #1
Opalmile's Avatar
1963 16' Bambi
Glen Arm , Maryland
Help, i cant open the door
Hi,
We recently bought a 1963 Bambi. I unlocked the deadbolt but the door won't open. I think the knob lock is acting up. I tried using the key but the knob just turns. What do I do?
Airstream newbie.
Opalmile is offline   Reply With Quote
Old 08-02-2013, 07:33 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Hi, and welcome to the forums!
Now to your problem--try posting a picture of your entry knob, as it might not be original, and we need to be sure of what we are talking about before trying to diagnose.
In general, though, look closely at the shaft behind the knob and make sure the shaft is actually turning as you turn the knob. When you say "the knob just turns," does it go round and round, or just a 1/4 turn in each direction? If it goes round and round, and the knob is turning the shaft, then the mechanism is probably broken internally. Contact the previous owner and ask if this is a problem they have seen in the recent past and if they have a trick to solve it. Is it possible to get inside the trailer via any of the windows?
Worst case scenario, the mechanics of the knob have failed internally, and you will have to gain access to the striker from the outside. Again, this will require knowledge of the anatomy of the knob, so a picture will be worth a thousand words.
Good luck!
