Old 03-05-2013, 02:16 PM   #1
1966 26' Overlander
Blue Ridge , Texas
Help!!!!!!
I am trying to find some barrel nuts to fit on my Phillips window controls (the window locks). Is there anyone out there that can help me??
redraider731 is offline   Reply With Quote
Old 03-05-2013, 02:48 PM   #2
Kevin245's Avatar
Sometimes referred to as Chicago Binding Posts?
If so, check out www.mcmaster-carr.com.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 03-05-2013, 03:33 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
These what you are looking for?
barrel nut cross dowel
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 03-05-2013, 04:00 PM   #4
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Try Andy at Inland RV.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-06-2013, 06:40 PM   #5
1966 26' Overlander
Blue Ridge , Texas
Ok so I figured it out. Used a tap and die set that i have in my Ag shop to reduce the threads on the screw after I took the entire mechanism apart. Then went to lowes and got some new metal barrel nuts that fit perfectly.
