The "skylight" astradome, as Airstream called it, is available from Vintage Trailer Supply. The lids, the best bet is to get on Facebook and hit up the various trailer parts pages like Vintage Airstream Parts Swap Meet, Airstream Parts, or even the Vintage Airstream Club page. Lots of folks pull them and put fantastic fans in so the parts are out there. 64Lincoln is correct, you're lucky having lifters that still work, make sure to lube them up well when you work on them. A side note those can be "unstuck", that's another thread though, but basically you can pry out the pivot rivet on the side, drive the shaft out, drill out the inner pin and drive the small shaft out, sand everything, then reinstall.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
