Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 09-03-2015, 06:46 AM   #41
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Itorgy - I didn't mention in reply #4 that the fix at the factory included removing the door, removing the skin of the door, replacing the mechanism and lock (including new keys), moving the striker and a hammering to bend the door. It has worked perfectly since. Why they didn't get this right at the factory is a mystery - such an expensive way to do business...
We shouldn't have to work out many (if any) bugs like this - but once you do - it is pure joy! Good luck!
Old 09-03-2015, 07:25 AM   #42
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Jackson Center needs to be aware of all QC issues. How else are they expected to know they have a problem? If they get a enough complaints on a certain problem they can hopefully see a trend and take action to fix the issues before sending trailers out the door.
MICHAEL
Old 09-04-2015, 08:35 AM   #43
2012 28' International
Prince Edward County , Ontario
Originally Posted by Dan Rossbach View Post
How do you do that from the inside?
Dan: See CWF's comment - I do something similar. I pull the handle in and slightly up and it works fine.
Cyclist is offline   Reply With Quote
Old 09-04-2015, 10:53 AM   #44
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
The Airstream dealerships refer to this as "the bank-vault slam." Considering the price of a new Airstream - they couldn't have come up with a better term!
Fly at Night is offline   Reply With Quote
Old 09-04-2015, 11:38 AM   #45
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
My 2016 must be closed firmly with a good slam or it only catches the first stop. My first night in the trailer I woke up the following morning & to my surprise I could see light coming in through the door jam, I gave it a slight push to realize it was totally unclosed. Being very security conscience that was a shock.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 09-04-2015, 01:11 PM   #46
Same thing happened to me. Tried to lock the door from the outside and it wouldn't lock. So, gave the door the ol' NHL hip-check, and the door was then totally flush and was able to lock it.
So, I slam away. Obviously, it was made for this.
Old 09-04-2015, 03:20 PM   #47
Mrjkq's Avatar
Venice , Florida
I guess that's why Patrick in his videos claims it closes like a bank vault door.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 09-04-2015, 10:36 PM   #48
2015 25' Flying Cloud
Eugene , Oregon
As mentioned earlier in the thread, I finally took my new AS back to the dealer and they fixed the problem. Now I can close the door with a firm close (one hand only) rather than a slam. Very refreshing and I won't wake up the neighbors at any park we are camped at when taking the dogs out. Certainly worth checking with your dealer about this. I actually watched a video made for dealers by AS that specifically addresses the issue of the hard-to-close door. So apparently, it's common enough to make a how-to video for all of the AS dealers.
ltorgy is offline   Reply With Quote
Old 09-05-2015, 06:09 AM   #49
AWCHIEF's Avatar
Images: 33
The door on my Safari takes a firm push to close. Like I suppose all Airstreams it can be sensitive to parking pad level and stabilizer tension. The old Bambi II was so warped and twisted out of shape that it took a hard slam to get the door shut all the way and still could see light around the edges. I do sometimes forget how easily the Safari door closes compared to the Bambi II and close it harder than necessary.
MICHAEL
Old 09-06-2015, 04:57 AM   #50
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
After adjustment at Jackson Center my door is somewhat easy to close.
Paul, the mechanic, worked on it for half a day.
He worked on "the list" for 2 1/2 days.
Then another mechanic adjusted my Equal-i-zer hitch. I got a better understanding of how it works and how to adjust it from him in the parking lot behind the service center.
Jackson Center is da bomb!
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-19-2015, 11:01 PM   #51
Revery's Avatar
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel , California
It needs to be adjusted, we recently purchased our 2nd AS in the last 12 months, a 28' FC and after the first trip, which was 5600 miles I noticed the door had become very hard to close, took the dealer two service stops to get it right but just got back from a short trip and it is good now. Our first AS was a 23' which never had a door issue, just cabinets falling apart. Problem I have now is still stuff falling apart, couple of trips ago the fresh water tank fell off in the middle of the freeway, then toilet broke and on the recent trip the cabinet in rear bedroom with TV on it fell off the upper support, forward ceiling fan starts and stops all by itself and the grey tank sensor won't register. Workmanship seems to be horrible on the new ones. It's frustrating but still fun and fortunately we have a great dealer and they just keep patching 'er up. Hopefully they will have fixed all the weak links in a few months, so when we are ready to do a lot of real long distance trips it will be solid. Every time they fix it they reinforce the work so it won't happen again. Anyway tell your dealer you don't want to pull the handle off the inside just to close the door "so fix it".
Revery is offline   Reply With Quote
Old 10-19-2015, 11:46 PM   #52
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
"Bob, Lee, and Dusty's random trips"
Hi, we were on the road for 3 1/2 months and sometimes my door closed easily and sometimes it needed a little more effort; This is just the nature of the beast. Trailers flex, and almost daily, we were parked/camping somewhere else.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 10-20-2015, 12:20 AM   #53
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Door slam
A little silicone sprayed on the door seal has helped mine close easier, yet it still requires a firm closing.
I suspect this means it is sealing well, less air entry....?
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-26-2017, 08:09 PM   #54
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
The door on our 2009 25FB Classic gets hard to open and close I get out the wd40 and lub the lock inside the door and wow. I can open with one finger. Magic.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
To have or not to have...vent covers??? Director Roof Vents, Skylights & Fans 2 10-21-2007 01:25 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
