Old 07-21-2015, 02:42 AM   #29
2015 19' Flying Cloud
2011 23' FB International
Dayton , Ohio
Ours is new and if you don't slam the door, it won't close even with the stabilizers up. If I just close it with my hand on the latch and put my weight on it, it will click but never latch completely. From the inside, slamming is the only option. I guess I will have the dealer look at that also.
Artvez is offline   Reply With Quote
Old 07-21-2015, 11:46 PM   #30
2015 25' Flying Cloud
Eugene , Oregon
Great ideas. Thanks. I will try to lubricate the latch mechanism and looks for loose screws in the hinges. That makes perfect sense. I should have my answer on these ideas in a day or two. We actually had to slam the door shut before we even bought the AS (no stabilizers down and empty tanks, etc.) Lyle
ltorgy is offline   Reply With Quote
Old 07-22-2015, 11:31 AM   #31
Ag&Au's Avatar
Port Orchard , Washington
If it's any help, mine got easier to close with age.
Ken
Old 07-23-2015, 03:13 PM   #32
Eugene , Oregon
I just went out to our AS. I used dry lubricant on the latch and checked the hinge screws. There were tight. The latch worked well. The latch seemed properly aligned with the post. The stabilizers were up. The windows were open AND I still had a hard time closing the door. I could use two hands to push on the door to close it from outside, but there is no way I can close the door from inside by just pulling on the handle without using the slamming technique. After watching the video from AS (on page 2 of this thread) I decided to let the dealer deal with this since it's a new AS and still under warranty. Thanks all for trying to help.
Lyle
Old 07-26-2015, 01:07 PM   #33
2004 22' Safari
Albuquerque , New Mexico
Originally Posted by Cyclist View Post
This is the method we use; let the door contact the frame and then press with the palm of my hand. This takes very little effort.
How do you do that from the inside?
Silver.Sanctuary is offline   Reply With Quote
Old 07-26-2015, 02:18 PM   #34
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
[QUOTE=Dan Rossbach;1658617]How do you do that from the inside?[/QUOTE]
Hi, that's the whole thing; They are relatively easy to close from the outside, but the real problem is closing your door from the inside. People have been known to break the inside door handle from pulling too hard on them.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-27-2015, 08:08 PM   #35
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Even on our 1999, it is hard to close with our new gasket.
To do this, from inside, I hold the inside handle as close as possible to the pivot point with my left hand. I then put my right hand on the screen door handle. Then with the door about 6 inches open, I pull 'snugly' on both doors. I release pressure just at the point I expect the door to fully seat.
You do NOT want to pull on the end of the outside door handle...that can break the handle...
With a little practice, yo will find you can put just enough pressure on the handles and 'speed' to achieve closure without 'slamming' the door.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-01-2015, 07:05 PM   #36
2015 30' FB FC Bunk
Ayer , Massachusetts
Originally Posted by Jukeboxfun View Post
Well ours did not close properly when we got it. Then the door latch post loosened on it's own. Before I used a crescent wrench to snug it up, I checked and adjusted the alignment. Works fine now.
Same here. You can actually move it around when it is loose to fine adjust it. Mine is perfect now.
Ted S. is offline   Reply With Quote
Old 09-01-2015, 07:07 PM   #37
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I have always had to close the door firmly from the inside. Usually takes two tries to get it closed. From the outside, it will close with a firm effort, but doesn't require a "slam". Lubricating the hinges, not the latch, made it easier to just swing closed.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 09-01-2015, 07:20 PM   #38
1972 23' Safari
Indian Head Park , Illinois
I had been having problems with my door not latching, and I came across this thread. I looked at my bubble level on the front of the trailer, and it showed the trailer to be not level. I adjusted the hitch jack until the bubble level was centered, and amazingly, the door now closes and latches easily as it should!
However, now my trailer appears to be tilting forward, even though the level indicates otherwise. If I drop a golf ball on the floor, it rolls all the way to the front. The trailer even looks like it is tilting forward. There are old jack stands placed under the back of the trailer near the rear bumper area that have been there for many years (docked at a campsite). Is there a proper way to check or adjust those?
thanks
amurfey is offline   Reply With Quote
Old 09-01-2015, 09:02 PM   #39
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Just got thru reading the section in Rich Luhr's new book, The (nearly) Complete Guide to Airstream Maintenance on door adjustment. Should be must reading for every Airstream owner new and old.
MICHAEL
Old 09-02-2015, 10:16 PM   #40
Eugene , Oregon
Update
Hi Everyone. After trying all of the suggestions in this thread and no luck. Fortunately, my new AS was under warranty and we took it to the dealer. We got it back recently and everything is fixed (with the door). I can't see what they did, but it closes with one hand without slamming it. Same with closing it from the inside. I wish I knew what they did, but the girl that checked us out knew nothing more than what an AS looked like. Unfortunately, they didn't fix the curved door under the sinks (both kitchen and bathroom). The doors were loose at the hinges. I suspect it came this way from the factory, but didn't see it until a few camping trips. I guess those hinges don't screw in well on curved doors. Yes, it's better, but there is still some play. I know how to fix these myself, the right way so I didn't complain about the crappy job they did on the loose doors.
Thanks again everyone for the suggestions.
Old 09-03-2015, 06:46 AM   #41
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Itorgy - I didn't mention in reply #4 that the fix at the factory included removing the door, removing the skin of the door, replacing the mechanism and lock (including new keys), moving the striker and a hammering to bend the door. It has worked perfectly since. Why they didn't get this right at the factory is a mystery - such an expensive way to do business...
We shouldn't have to work out many (if any) bugs like this - but once you do - it is pure joy! Good luck!
Old 09-03-2015, 07:25 AM   #42
AWCHIEF's Avatar
Images: 33
Jackson Center needs to be aware of all QC issues. How else are they expected to know they have a problem? If they get a enough complaints on a certain problem they can hopefully see a trend and take action to fix the issues before sending trailers out the door.
MICHAEL
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
To have or not to have...vent covers??? Director Roof Vents, Skylights & Fans 2 10-21-2007 01:25 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
