Old 07-20-2015, 12:41 PM   #15
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Open a window or vent. Does the door close more easily?
Kelvin
Old 07-20-2015, 01:13 PM   #16
knunut's Avatar
Chgo. N.W. Burb's , Illinois
Even on a 20ft., if you crank levelers down too much door is hard to close.
We do same ,down to ground plus 1/2 to 1 full turn. I also check after a day or two.
knunut is offline   Reply With Quote
Old 07-20-2015, 01:35 PM   #17
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
What ROBERTSUNRUS said and several others have advised. Unless you level the trailer with the wheels and axles, you will torque the body and give your door fits.
Check this out:
Finally by slamming the door, you'll eventually bend the little pot metal locking mechanism within the door latch mechanism so the Paddle Opener (does it have a name) won't function. Been there.
The Ice Man is offline   Reply With Quote
Old 07-20-2015, 02:00 PM   #18
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I agree with lubing the latch contact points. Then to close just place your palm on the door and firmly close it- keeping your palm on the door till the end.
2019 Ford Expedition Platinum
Wayne&Sam is online now   Reply With Quote
Old 07-20-2015, 02:13 PM   #19
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton , California
Send a message via AIM to tyggeln Send a message via MSN to tyggeln Send a message via Yahoo to tyggeln
Everybody seems to suggest that its OK to slam the door, and I have seen AS guys on you-tube extolling the virtues of the AS by slamming the hell out of the door.
With the conservatism shown by the group, I am rather surprised that slamming the door is seen as OK. As with any mechanical interface, the more times you stress it, sooner or later it will fail. Not to mention it's loud and wakes up my wife, since I am the one to take the dogs out in the early AM or go stargazing late at night - while she sleeps.
I close the door using the technique learned in the US submarine force - if on the outside of the door, I gently bring the door into contact with the frame, and then push shut with my hand on the door, until I hear the latch click. If I am on the inside, I similarly make quiet contact, and the pull the door shut until the latch clicks.
Regardless of what we think of the ability of the AS to absorb abuse, its not necessary and can be avoided.
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
tyggeln is offline   Reply With Quote
Old 07-20-2015, 02:14 PM   #20
Kelvin
That's one air tight trailer!
Old 07-20-2015, 02:37 PM   #21
2012 28' International
Prince Edward County , Ontario
This is the method we use; let the door contact the frame and then press with the palm of my hand. This takes very little effort.
Cyclist is offline   Reply With Quote
Old 07-20-2015, 03:56 PM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It might have already been mentioned, but...
To make the door easier to close:
When leveling the trailer, place your level on the door sill. This is how Jackson Center says to do it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-20-2015, 04:28 PM   #23
TopGeorge's Avatar
2007 25' Safari SS SE
Crowley , Texas
you may also want to check the screen door every once in a while- just to be sure it isn't adding to your degree of difficulty in some form or fashion. Btw: We close my door by bringing it to (easily close to first click) then pushing (as stated) or firmly grasping/pulling handle to finish. Finally, my first post. Hello you beautiful people!
TopGeorge is offline   Reply With Quote
Old 07-20-2015, 04:29 PM   #24
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Our latch was quite misaligned. I spent some time understanding it and massaging it, and now it works much better. The large stud in the door frame that's grabbed by the jaws in the latch was way out of position. It can be loosened with a wrench and coaxed around quite a bit to get it to meet the center of the jaws.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 07-20-2015, 05:16 PM   #25
Rjpuckett's Avatar
2012 25' Flying Cloud
San Antonio , Texas
I have the same problem with mine. Leveling properly does make a difference. At night from the inside I just give it a pull and hear a click then pull it once more for the final click. The click is louder when I open the door. Feel for any tents near me when I open the door early in the AM.
Rjpuckett is offline   Reply With Quote
Old 07-20-2015, 09:21 PM   #26
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Yah', it's new! So is my '' Cloud' and I have to slam the door; so what do you expect? A Cadillac?
MelGoddard is offline   Reply With Quote
Old 07-20-2015, 10:15 PM   #27
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have to 'push' my door closed... or 'slam'... to compress the gasket around the door.
Of course it is a 1999... I replaced the door gasket and it really 'snugged' it up!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-20-2015, 11:46 PM   #28
Ag&Au's Avatar
Port Orchard , Washington
It requires finese not force.
I close the door with much less force than I would use on a car or truck door. If it catches, but doesn't fully latch, I simply press on the door edge where the latch is. It usually latches with a firm press. Once again, keep it lubricated.
Ken
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
To have or not to have...vent covers??? Director Roof Vents, Skylights & Fans 2 10-21-2007 01:25 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
