Old 08-23-2019, 04:06 PM   #1
RxGuy's Avatar
2010 27' FB International
Bois Blanc Island , Michigan
Gray window knob set screws..
I searched this site for a "how to" fix the loose gray window knobs. I found several references to some creative fixes involving threading the ends of the rods, etc, and a suggestion to thread the hole by user greghoro.
Using greghoro's suggestion about threading the hole.
Here's what I did, and what you need.
1/4"-20 tap
1/4"-20 set screws 1/4" long
Allen wrench to fit set screws
No drilling necessary, the 1/4"-20 tap will thread the hole quite nicely. If you wish to put a flat on the window rod, add a file (or Dremel tool) to the list. I did not put flats on the rods. The set screws seem to be holding well, and it stops the knobs from turning or coming off. You can tighten them securely, just be careful not to strip them out.
Blair
RxGuy is offline   Reply With Quote
Old 08-23-2019, 06:06 PM   #2
LilBigfoot's Avatar
2016 26' Flying Cloud
London , Ontario
You could just purchase nice new shiny ones....https://www.vintagetrailersupply.com...-p/vts-294.htm
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 08-24-2019, 07:40 AM   #3
RxGuy's Avatar
Had the tap, had the set screws....zero out of pocket expense. Total investment about 45 minutes of time.
Thanks for the link.
Tools wanted - Buck rivet set and Cleco set TinCan Don Ribs, Skins & Rivets 0 01-14-2019 07:46 PM
Original Bargman door knob / lock set TAG Airstream Classifieds 0 04-02-2016 08:37 AM
Window handle set screws lsbrodsky Windows & Screens 3 12-22-2015 05:55 PM
Are the knobs on the window opening levers supposed to have set screws in them? m.hony General Repair Forum 5 10-25-2012 11:55 AM
Questions on hitch set set up for my Dodge Astriking Hitches, Couplers & Balls 13 04-25-2011 05:03 AM
