Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 08-07-2006, 12:28 PM   #99
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by RVnDixie
Insideout,
Reglazing? I'm not sure what kind of windows I have in my '75 Argosy. But some of them look terrible! (Kind of milky look to them). I would like some more info on the reglazing if possible. The windows are in good shape other than not being "clear". Also, is there anyone who sells replacement parts for the plastic pieces where you raise the windows with the bars and set in the slots for varying heights? Any info much appreciated! Thanks!
All 1969 side opening windows as well as all the Argosy side opening windows, "ARE" curved tempered glass.
Sounds like someone may have tried to tint your windows.
We have the window position guides.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-25-2006, 09:41 PM   #100
soldiermedic
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Gasket for 68 Windows
Aside from the glass in my 68's windows, everything else is in poor shape. My biggest issue is a rock hard gasket that that is on every window. Looking at Inland, I see they offer a door gasket/window gasket for my year. I know that the gasket inland sells is not what is on my windows currently, but I don't know if what I have is OEM or not (Probably not). Is the gasket sold from Inland the best for the 68, or should I search out a D-style weathertripping that will actually collapse when the window closes against it?
SM
soldiermedic is online now   Reply With Quote
Old 11-26-2006, 04:20 AM   #101
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
SM
Did you look @ VintageTrailer?
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 11-26-2006, 07:06 AM   #102
soldiermedic
Commercial Vendor
O'fallon , Missouri
Yes I did
but when I looked I did not see anything specificly for the 68.
Old 11-26-2006, 07:54 AM   #103
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
We used the stuff that Andy sells at Inland. It works just fine and seals well. Just follow Andy's instructions on how to place the rubber into the window, and use some good monkey-snot as glue. Oh, you can get black monkey-snot; the yellow kind that I used is less appropriate.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 11-26-2006, 09:58 AM   #104
soldiermedic
Commercial Vendor
O'fallon , Missouri
When I bought the door gasket there was no instruction sheet sent. I know the gasket I am wirebrushing off didn't look like the stuff I was sent. Anyone have pointers on how to install this stuff with the black weatherstip adhesive? I am mainly soncerned with the corners and the bottom of the door.
Old 11-26-2006, 10:20 AM   #105
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
... Anyone have pointers on how to install this stuff with the black weatherstip adhesive? ...
There's a writeup at my web site (link in signature).
Tom
[IMG] code is Off
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 06:47 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
