Join Airstream Forums Today
Old 12-22-2011, 10:03 AM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Gasket for windows/door on 31'
How many feet of D gasket are needed for a 31' 1971?
Darkspeed is offline   Reply With Quote
Old 12-22-2011, 10:49 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Obviously most correct answer is gained by the old motto (paraphrased here) "Measure twice order once"! Also use the same "D" gasket for the entry door seal. It was over 30 feet that I ordered for my trailer and I had to order 6 feet more as I damaged some spots from folding it during storage. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
BIGED52 is offline   Reply With Quote
Old 12-22-2011, 10:49 AM   #3
Windows= 78 feet
Entrance door= 16 feet
Access doors= 19 feet.
Adhesive 1 tube per 25 feet.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 12-22-2011, 04:31 PM   #4
Darkspeed's Avatar
1972 31' Sovereign
Originally Posted by Inland RV Center, In View Post
Windows= 78 feet
THanks Andy!!
Old 01-23-2012, 09:27 PM   #5
1972 31' Sovereign
1973 31' Sovereign
Where are you getting yours from?
Regards
Still One Nation Under GOD
VeggieBullet is offline   Reply With Quote
Old 01-23-2012, 10:00 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Got my "D" gasket from local A/S dealer. Works very well as the replacement for the old dry rotted rubber gasket. Remember, don't cut at the corners and try not to stretch it. Ed
AIR#7110
Burma Shave
[IMG] code is Off
Where to get running light gasket ? MrJ Lights - Interior & Exterior 5 09-08-2011 06:57 AM
Argosy exterior Flood Light Gasket buffaloman Lights - Interior & Exterior 3 07-11-2011 06:41 PM
Main Door Gasket Replacement Dog Doc Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 04-24-2011 07:24 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
