Old 11-04-2016, 12:13 PM   #1
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Frustrated with "dropped" shower door?
If, like us, you have been frustrated with a shower door that has dropped on the hinge side and catches at the bottom on the handle side, here is a solution. After many times of pulling up from the door top/handle when both opening and closing the shower door, we discussed this with a friend at Alumalina this past weekend. He had replaced his door but suggested using a nylon washer on the bottom hinge pin by splitting the washer. Unfortunately, there is no accessible pin on our door. When looking through my "junk box" at home I found these nylon spacers/washers that I had decided to save. The spacer/washer is 3/4" outside diameter and 7/16" thick. I simply placed it in the track at the hinge side after pulling the door up. I sprayed the top of the spacer with dry silicon lubricant as an extra measure. The door dropped right down on the washer and smoothly and perfectly opens and closes decreasing the frustration and aggravation. The weight and pressure of the door holds it in place. These spacer/washers might be found in a box store or hardware store.
ID:	274783   Click image for larger version
Silverbee is offline   Reply With Quote
Old 11-04-2016, 12:44 PM   #2
interstateflyer's Avatar
2017 25' International
Los Osos , California
good idea...thanks
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 11-04-2016, 12:55 PM   #3
2005 30' Classic
Burlington , Ontario
So the pin on the door is long enough to go right through the 7/16" spacer and still engage in the frame ok?
Did you lift the door right out to install it or did you cut a slot in the spacer with a Dremel tool or similar?
Our shower door has always suffered the same problem!
Brian.
Old 11-04-2016, 03:00 PM   #4
Silverbee's Avatar
2007 20' Safari SE
Brian.
On our shower door there is no pin from the hinge. The door seems to slide up and down on the hinge side. So I just pulled the door up and placed the nylon spacer underneath the hinge side. The weight and pressure holds the spacer in place.
Old 11-04-2016, 03:49 PM   #5
2005 30' Classic
Understand - thanks! Maybe ours has no pin either, I just assumed it would have! (Our trailer is in storage until Feb.)
I know that on ours there is an adjustable hinge bracket at the top of the doorand its set screw sometimes comes loose allowing the door to angle over and jam - I have had to address that a couple of times. Never really looked closely at the bottem end, but we have to do just as you described and lift the handle end to be able to open the door properly - would like to resolve that.
Brian.
Old 11-04-2016, 05:06 PM   #6
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
Smart fix!
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 11-05-2016, 02:39 PM   #7
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
See the following posts on previous discussions for the same problem.
http://www.airforums.com/forums/f520...ml#post1703084
http://www.airforums.com/forums/f44/...nt-124069.html
http://www.airforums.com/forums/f446...ped-94602.html
http://www.airforums.com/forums/f164...ue-123619.html
http://www.airforums.com/forums/f142...ix-127887.html
http://www.airforums.com/forums/f164...rd-140613.html
I first used the nylon spacer under the hinge approach but found that it only provided a temporary solution. The problem is that the door is only supported by two screws going horizontally from the hinge into the door. The leverage from the weight of the door along with the up/down motion from the road causes these screws to bend.
Based on a comment from one of the threads I linked to, I installed a piece of 3/8" PEX (1/2" OD) along the bottom door frame to support the full width of the door when it is closed. No more sagging.
We rarely use our shower, so I can't reply to questions on the long term potential risks of water leaks caused by the screws holding the PEX to the bottom door frame.
Greg
greghoro is offline   Reply With Quote
Old 11-05-2016, 04:10 PM   #8
Dan and Lynda
2012 28' International
Bremerton , Washington
I have had this problem. I have cut a piece of Delron (Nylon) rod 1 1/2 inches in diameter, .655 inches thick and then put a groove in one side that lines up with the lip on the shower door frame. Then slide it in and it will be held in place by the groove. The thickness may be slightly different for your application. I sanded it down to make the final thickness and rounded the edges with 150 grit or finder sand paper.
The Cralls is offline   Reply With Quote
Old 11-08-2016, 03:16 AM   #9
2012 30' International
Livingston , Texas
Greg
X2- but better to use adhesive instead of screws
glenrms is offline   Reply With Quote
Old 11-08-2016, 06:51 AM   #10
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Greg
Sounds like a very good fix but any chance of getting a picture of that ?
TRIPPPIN is offline   Reply With Quote
Old 11-08-2016, 08:23 AM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I had this problem after a severely washboarded road. The upper screw bent under the weight of the door. It can then slide down. However, it is supported by the full length of the hinge so it can't do anything but go straight down.
I cut a plastic bottle cap to use as a shim to get me through the trip. When I got home I made a shim out of a piece of plastic cutting board.
http://www.airforums.com/forums/f44/...or-155128.html
2019 Ford Expedition Platinum
Old 11-09-2016, 07:50 AM   #12
greghoro's Avatar
Wheaton , Illinois
Perhaps but I felt that a mechanical attachment (screws) would better withstand the rigors of being pushed against when closing the door. The bottom of the door actually rubs against the top of the PEX tubing. The round cross-section of the tubing provides a narrow point of contact for an adhesive to adhere to at the door frame and naturally rolls when force is placed in the opening and closing direction. And one would have to find an adhesive that would stick to both aluminum and slick plastic. I did put a bit of sealer at each hole in the door frame before placing the PEX as well as on the underside of each screw, more so for waterproofing than adhesion.
Give it a try and let us know what you used and how it works out for the long term. Adhesive would certainly be easier than drilling precise holes evenly and in the same plane along the tubing without the aid of a drill press and V blocks. Note, the holes at the top of the PEX have to be drilled big enough to allow the head of the screw to pass through while the hole at the bottom is only drilled big enough to allow the shaft of the screw to pass.
When showering, the holes are covered by the door.
Here is a picture of my install.
Name:	ImageUploadedByAirstream Forums1478702534.244477.jpg
Greg
Old 11-09-2016, 08:40 AM   #13
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We had similar problems and tried similar fixes which all worked in the short term. When our shower door finally shattered on a rough road, we just took it out and now use a shower curtain. I was skeptical that the shower curtain would be acceptable but frankly I prefer it to the door as when the curtain is open (to get in and out of the shower) it does impeded access in the bath/toilet area. If I had a new Airstream, one of the first mods I would do would be to remove the shower door.
Bob Martel
WBCCI# 5766
Old 11-09-2016, 08:51 AM   #14
2020 Classic 33 on order
Box Elder , South Dakota
I had mine fixed at the factory. Same issue on my 2014 FC and 2015 Classic. The factory cuts a piece of nylon plastic solid square tube about 1/2x1/2 by maybe 1/2-3/4 long. Drills a hole through it lengthwise and the screws it into the side wall of the door (horizontal to the bottom of the door) so that it is under the hinge side of the door.
Issue is that there is a height adjustment screw that runs down the hinge side of the door at the top (along the spine of the door). It simply isn't strong enough to support the door while we drive our rigs. Washboard roads are the worst.
Quick easy fix.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Frustrated with "reading lights" in my 22 Sport Belbein Lights - Interior & Exterior 0 05-17-2016 11:01 AM
Has anyone 'streamed while on crutches? I'm soooo frustrated... J5MM Off Topic Forum 11 07-23-2011 10:43 AM
Frustrated with New Dometic NashBuff Refrigerators 6 07-29-2010 10:02 PM
So frustrated! Foiled Again Off Topic Forum 4 07-17-2008 01:59 AM
