Old 06-23-2019, 06:11 PM   #1
2019 23' Flying Cloud
Beach Park , Illinois
Front window shields
Anyone else having trouble with the anchor 1/4 turn screws that hold the new window shields in the lock down position? One side of mine are either stripped out or never really caught that well. I'm afraid of them coming undone while traveling. I'd rather the same kind of anchoring they used on the rock guards. A nut on a threaded machine screw.
Any advise or options would be appreciated.
51hunter is offline   Reply With Quote
Old 06-23-2019, 06:51 PM   #2
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
I had the same problem. I modified mine to be through bolted just like the rock guards. I drilled out the rivets that attached the rubber mount on the 1/4 turn mounts. Slipped in a machine screw. Put a washer and nut to hold the machine screw. Removed the 1/4 turn screw. Reriveted the mounts put the rock guard back on and put a locknut on to hold the rock guard. This modification has been working perfectly for 35,000 miles.
Here are pictures of how I did this modification http://www.airforums.com/forums/f42/...ml#post1996232
2017 Flying Cloud 25FB (Miles) 310 nights 39,100 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's, TM66 TPMS
2019 F250, 6.7 Power Stroke, 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 06-24-2019, 01:22 PM   #3
I just did the same thing here but I was lucky enough to have some old brackets which look like the rubber catch part and put a machine screw through the center. Then re riveted it back and used a lock nut. Permanent fix and stronger.
Thanks for the heads up.
Old 06-27-2019, 10:55 AM   #4
2019 16' Sport
Vancouver , British Columbia
I have the exact same issue, wouldn't this be covered under warranty. Would this have been a factory issue or did I do something wrong? I only unscrewed the one side to clean behind the window and could not get it to relatch. I am not sure if i want to start modifying something that is still covered, i hope?
Alilee is offline   Reply With Quote
Old 06-27-2019, 11:10 AM   #5
2019 16' Sport
One additional comment, i put a screw driver into the locking side and instead of being fixed in position they spin, which means they would never lock, I am not sure if this is normal operation? I was afraid to unlock the other side to find out!!!
Old 06-28-2019, 04:55 PM   #6
That's the problem I had. Mines never been on the road except 50 miles to get her home. So I figure if you claim warranty I'd bet they'd just put the same thing on. Problem not solved. That's why I changed mine out.
Old 06-30-2019, 07:17 PM   #7
2017 28' Flying Cloud
Sneads Ferry , North Carolina
I recently was at the factory for a service prior to warranty expiration. Tech checked mine because of concerns. One half hour down the road I see the rock guard in my rear view mirror dancing in the wind. Fast forward factory sent me a new rock guard screws already in place and a second set of screw/fasteners with a little more length. My 2017 Flyingcloud needs the longer fasteners. The other option may be to remove some of the bushing thus changing the depth and allowing better grip of fastener.
ARHokie is offline   Reply With Quote
Old 07-01-2019, 10:09 AM   #8
2019 16' Sport
That was my first thought that the screws were not long enough and weren't catching. I am relatively strong but was still unable to make the screws latch. Is it normal operation for the anchors to spin? (I inserted a screw driver and was able to so spin both of the them) I was afraid to open the other side, just incase i was doing something wrong!!!
Star cracks (rock chips) in the front shields already... tbennett017 Rock Guards, Segment & Window Protectors 2 08-29-2018 07:05 AM
Plexiglass window shields JimGaskill On The Road... 7 02-25-2017 12:16 PM
Walberize and the front stone shields bernermom Cleaning, Stripping & Polishing 6 09-07-2008 03:07 PM
Removing Smoked Plexiglass Window Shields Lee Davis Windows & Screens 4 09-13-2005 02:41 PM
window shields Lexxy Rock Guards, Segment & Window Protectors 13 08-18-2002 06:30 PM
