Old 06-29-2019, 08:12 AM   #1
SpiffyIM's Avatar
2019 25' Globetrotter
Knoxville , Tennessee
Front Window Shield Frame
I have a new 2019 Globetrotter. I was cleaning the front after our maiden voyage. I noticed the two front end (side) plexiglass rock guards that are hinge mounted at the front do not fit against the Airstream curves and window. Does anyone else have this issue or do I have a bent rock guard frame on my trailer?
The guard has a gasket around the inside of the frame implying it should fit against the body of the Airstrem for some sort of seal. But the frame has large gaps at the top side portions of the frame.
SpiffyIM is offline   Reply With Quote
Old 06-29-2019, 06:30 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
Rock guard.. it is untended to flex. The “gasket” is the next level of shock absorption if necessary. Also if wind pressures exceed then the gasket provides additional resistance. So, of it doesn’t touch I would not worry. Easier to hose out and keep gasket clean so it doesn’t scratch against frame if gritty
71 Caravel window shield miracle needed markdubin Windows, Doors, Locks & Vents 2 05-03-2019 12:33 PM
Front window Shield Repair TucsonDon General Repair Forum 1 04-04-2019 02:03 PM
Front curved pexiglass window shield blowoff! chaimemet On The Road... 0 11-20-2011 07:01 PM
visibility thru Window rock shield Grand Master Rock Guards, Segment & Window Protectors 17 01-25-2008 06:13 PM
plastic shield for front window 66 overland Rock Guards, Segment & Window Protectors 4 10-06-2006 10:13 AM
