Old 01-05-2014, 12:14 PM   #1
LisaH's Avatar
1985 31' Sovereign
Monterey Bay, CA , California
Front door window replacement resource for 1985 31ft Sovereign
Well, thanks to the help provided here in response to my last question regarding batteries, it is now time to move on to replacing the shattered front door window of my 1985 Sovereign. Any recommendations for a reputable resource in the California area?
LisaH is offline   Reply With Quote
Old 01-07-2014, 02:05 PM   #2
LisaH's Avatar
1985 31' Sovereign
Window installation tips
Looks like Inland RV is the best bet for window replacement materials, plus a rivet gun. Does anyone have any tips for removing/installing a fixed door window and/or solid hinge window? Any advice is welcome. (I can see the lessons here have just begun!)
Old 01-07-2014, 03:35 PM   #3
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
The entry door window is held in place with buck rivets and can be removed by drilling those rivets out, then install the new window and frame with the same buck style rivets.
The hinged windows on the front/back and sides are referred to as a "glass & sash" they can be removed by removing the lift arm mechanisms then elevating the window gently past 90į, the window will drop out of the mating hinge. re-installing is the reverse, but easy, stop if you start to feel resistance at the hinge and re-position it or you'll pop the hinge of the frame.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 01-08-2014, 11:42 AM   #4
LisaH's Avatar
1985 31' Sovereign
Thanks Greg for your help here. I'll admit, you make it sound quite easy....hopefully the installation will go smoothly.
Have a great day!
Lisa
Old 01-08-2014, 11:47 AM   #5
LisaH's Avatar
1985 31' Sovereign
Hi Greg,
A quick question if I could, from the help I've hired to get this done:
Are the buck rivets removed by drilling them out from the face?, or from behind by grinding them out.
Lisa
sovereign
