Old 05-23-2014, 07:30 PM   #1
2014 30' Flying Cloud
Ponce Inlet , Florida
Front door upper hinge pin
I noticed the front door upper hinge pin was out about 1/2 inch. Whacked it back in place with rubber a mallet. We have a 30' 2014 FC with about 3k miles. This newbie wants to know if this is normal ?
Sent from my ADR6400L using Airstream Forums mobile app
Beach Bum is offline   Reply With Quote
Old 05-23-2014, 08:00 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It happens. There are a couple of fixes, the cheapest and most effective fix is to drill a hole through the hinge, through the pin, and tap a 1/8" roll pin into the hole. It will never come out again. Open the door and drill the front-facing part of the hinge so it will be less noticeable.
Old 05-23-2014, 08:31 PM   #3
Your trailer is being shaken.
Some of the causes are excessive rated hitch bars, excessive rated tow vehicle, and the biggest cause is lack of proper running gear balance.
Installing some Centramatic balancers will cure the balance issue.
Old 05-23-2014, 08:49 PM   #4
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
I second that. I took the same measures with mine 6 months ago and no further issues.
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 05-23-2014, 09:08 PM   #5
SteveH's Avatar
Common Sense , Texas
There's an easier fix that requires no drilling. Clean the surface of the hinge where the pin goes in, and that area of the hinge pin with any solvent that will remove the oil that might be on it. Tap the hinge pin back in place with RED Locktite liberally applied around the area, and let it set over night. It will not come out again.
Regards,
Steve
Old 05-24-2014, 05:04 AM   #6
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Why didn't you tell me that before Steve. I didn't really want to drill into my trailer. But, it worked and it really doesn't show.
Old 05-24-2014, 06:02 AM   #7
SteveH's Avatar
Well, maybe because you didn't ask???
Regards,
Steve
Old 05-24-2014, 12:21 PM   #8
Thanks all, just got home and the pin pop up again. Will fix before we leave again on Tuesday. We prefer to be home on holiday weekends too may crazy's in the campgrounds.
Old 05-24-2014, 03:24 PM   #9
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Agree -agree! Nothing ruins a great holiday like amateurs screaming and carrying on until all hours of the night, harshing the mellow you sought. I liken it to New Year's Eve when the same thing is true. I always called it amateur night.
And while my wife and I thought we'd bring in the new year in our AS this past January, in a quiet campground in the mountains..... At about 4pm our empty park started filling up with people, all young. We of course were able to bring in the new year on the east coast (we live on the west). But, 2 hours later we were awoken by our neighbors - all of them - as they hooped and hollered until the wee hours! Happy New Year... Not so much.
Old 05-24-2014, 04:32 PM   #10
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
We had the same problem with the top pin coming out on our 2006 Classic. We tried installing the Centramatics as Andy suggested as well as the Locktite. Didn't work. We took it to the dealer who put in the new version pin and haven't had a problem since. Glad we got the Centramatics though
kswelsh is offline   Reply With Quote
Old 05-24-2014, 05:36 PM   #11
dznf0g's Avatar
Oswego , Illinois
The new grooved and e-clipped pin is the easy clean non-intrusive fix. They are about $20 each though.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 05-24-2014, 06:37 PM   #12
1974 Argosy 20
Kooskia , Idaho
On a 2014 trailer, it is a dealer warrantee issue. Let them fix it, we pay enough for the trailer to begin with. You have 2 years of service free. Use it.
Old 05-24-2014, 09:43 PM   #13
Centramatic's are in my future plan to get them after I get back in July. Makes a lot of sense.
Read a lot of the running gear info on the board lots of conflicting info and folks who swear by whatever they have. Did not realize that running gear topic is as volatile as politics and religion
I have the grooved pin. Maybe the e clip may have failed I will compare with the lower hinge and call AS customer service.
If not will try one of the other fixes.
If a dealer was closer I would take it there. Cost me more in gas and time than this is worth if I can fix easily.
Old 05-25-2014, 06:24 AM   #14
dznf0g's Avatar
Oswego , Illinois
By grooved, I'm now talking about the knurled top...I'm talking about a land cut around the circumference where the washers are between the two halves of the hinge. There should be several round washers for variable door height and an e-clip in the upper gap.
Just to be clear.
If the clip is there, there is no way for the pin to walk up.
-Rich-
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
'78 Sovereign needs upper door hinge sharris1199 Doors & Locks 0 09-07-2009 07:25 PM
door hinge worn not the pin silver 67 Doors & Locks 5 08-11-2004 08:30 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
