Join Airstream Forums Today
Old 06-06-2011, 10:13 PM   #1
1974 29' Ambassador
coeurdalene , Idaho
Foggy front curved windows
Any ideas how to clear the moisture from in between the two curved window glass panes on front of a 74 ambassador without removing frame from the shell??
adamgraves is offline   Reply With Quote
Old 08-04-2011, 05:15 PM   #2
1973 25' Tradewind
waynesboro , Virginia
On my 73 I verrrry carefully drilled from the underside , up between the two pieces of glass, allowing the moisture to escape, waited a couple of days , filled the drill holes with putty....I was worried that I would break one of the pained, but it worked.....
Waltero
waltero is offline   Reply With Quote
Old 09-24-2011, 07:45 PM   #3
1971 27' Overlander
rogers , Minnesota
Broken curved front window
I shattered the right front window on my 1971 Overlander. Does anyone know if these are still available and how hard it would be to replace?
tommybb is offline   Reply With Quote
Old 09-24-2011, 07:52 PM   #4
Lumatic's Avatar
1967 24' Tradewind
Estancia , New Mexico
Images: 11
1.You can carefully break out the inner pane
2.Yes new replacement widows are available, but expensive. Try Inland RV. Used are also available 1970 to 75 R the same. Not too hard to replace but takes some time.
Turn left right here
[IMG] code is Off
NEEDED: Two front windows for 71 overlander jesse_kevon Windows, Doors, Locks & Vents 2 04-10-2011 10:06 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Vista View Windows.. this can't be right DanielB Windows & Screens 10 03-01-2011 09:22 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
