Old 07-09-2017, 11:10 PM   #1
Stork's Avatar
1976 Argosy 28
1975 31' Sovereign
1973 Argosy 24
Edmonton , Alberta
Fantastic Fan in place of AC
Here is my issue, I want to put a Fantastic Fan in my 28' Argosy. The previous owner had removed the AC so the 14" square hole awaits, and the extra bit of light in the kitchen area would be great. The problem is the edge facing the front will require drilling into the support rail. If I attempt this will I be able to screw into the rail? Also being there is no flex at that point I may also have an issue with the fact that the new vent is perfectly flat and the roof has a curve. Has anyone else here attempted this? Any advice would be awesome!
Thanks!
Stork is offline   Reply With Quote
Old 07-10-2017, 07:16 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
If I recall correctly, when I installed a new FF one end of it was right against a support rail. It caused me no problems.
CRH is offline   Reply With Quote
Old 07-10-2017, 08:04 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
As for the curve that is the same problem when installing a newer AC unit. They use closed cell foam to make the seal and account for the curve.
Foam to fill the gap and RTV to ensure a seal to the roof.
2004 Excursion 4x4
Newbie bringing AS from our place in Canada to our place in the US for the first time cyclistream 1974 - 1977 Overlander 9 03-29-2017 07:02 PM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Original fan vs fantastic fan KYAirstream Roof Vents, Skylights & Fans 16 08-14-2015 04:51 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
