Old 10-13-2014, 04:54 PM   #1
2015 25' FB Eddie Bauer
EUGENE , Oregon
factory supplied front window guard
I just bought a new 2014 25 ft with factory front window guards and the gaskets do not seal against the trailer, they do prevent the window from rubbing but do not seal, my queston is should they? they are about 1/4 to 1/2 inch away from trailer.
brianeharris is offline   Reply With Quote
Old 10-13-2014, 04:57 PM   #2
They can be bent to fit flush, but you must know how, or you will crack the plastic.
Old 10-13-2014, 05:20 PM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Those gaps are common in all the AS's I'm aware of. But there's an easy solution.
Home Depot/Lowes has outdoor foam insulation which protects the freon/coolant line going into your house.
Use it to line the upper gaps between the actual gasket and window.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-13-2014, 05:42 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My new window rock guards don't seal against the body either. I get leaves and bugs between the guard and the glass. But they open up for cleaning when I get a round tuit.
David
Old 10-13-2014, 06:14 PM   #5
1974 Argosy 20
Kooskia , Idaho
No, they don't seal and have gaps. Sealing them will hold the bugs and stuff which most assuredly will get in much better but will not keep it out. Open them up once or twice a year and clean inside would be my advice. Don't bother to try to seal them up.
Old 10-13-2014, 06:44 PM   #6
2019 27' Globetrotter
Missouri Valley , Iowa
Be careful when you loosen the latches! The wind will take them and put a not so nice crease at the back end of them by the hinges. They lift upward off of the hinges to clear the area for complete access if you want to. You have to have the center piece up to access the 2 latch screws, though.
Dan
Farmer Dan is offline   Reply With Quote
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Front window obstructed by window guard....HELP! vincaroo Windows & Screens 9 06-16-2014 08:20 PM
factory supplied converter and batteries rayandre Batteries, Univolts, Converters & Inverters 9 02-23-2011 05:47 AM
Front Window Plexiglas Guard Replacement boltos Rock Guards, Segment & Window Protectors 29 08-25-2009 06:00 PM
Finally - Found a use for the AS supplied pillows! Bambi_Bandit The Pet Forum 2 11-09-2004 09:55 AM
