Join Airstream Forums Today
Old 11-13-2011, 05:49 PM   #1
1962 24' Tradewind
Kansas City , Missouri
Exterior/Main Door Doesn't fit frame
I'm new to Airstreams and the renovation process, so any and all info/help is appreciated...
I just purchased an exterior/main door for my 1962 Tradewind (it's original door was cut, cracked and torn apart). The door fits nicely at top and bottom of frame, but when lining it up I noticed the curve of the door comes out an inch further than the frame at the sides. Therefore, the door cannot even latch due to this gap. I am wanting to get this fixed and the door installed before winter really hits, so I'm hoping there is an easier fix than major welding, removing skins, etc. A friend (that doesn't have much experience) mentioned using wood blocks to somehow bend the door into place? Not sure if this is a feasible option but I'm up for anything at this point...
Thanks!
Angary is offline   Reply With Quote
Old 11-13-2011, 06:12 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Some ideas here...
http://www.airforums.com/forums/f453...oor-26820.html
If you do a search for sprung door or bent door , you'll find other threads that may help too!
_________________________
Vintage Spare Tire Cover
Shelly
TAC NH-6
AIR 41359
Visit my restoration blog!
http://63overlandermoonraker.blogspot.com/
Are you going to the restoration rally 2012? I am!
Parts needed :
Refrigerator "thru the "roof" vent
reinergirl is offline   Reply With Quote
[IMG] code is Off
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
69 Overlander frame repair colin57 Repairing/Replacing Floor &/or Frame 6 04-25-2011 10:45 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
1965 Caravel Frame funhouse 1965 Caravel 0 03-01-2011 09:12 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
