Old 03-24-2017, 07:51 AM   #1
1989 34' Excella
Entry Door Jamb Padding?
I've clobbered my head more times than I can count exiting my '89 Excella. You think I'd learn, but ...
Is there a ready-made product that would snap, clip, or otherwise affix onto the top of the door jamb to pad it against head-strikes? I'm surprised something like this doesn't exist, but wasn't able to find it via Google.
Alternately, has anyone rigged up a computer wrist rest or similar to pad the jamb? Surely I can't be the first one to, um, run into this problem ...
MohawkDaddy is offline   Reply With Quote
Old 03-24-2017, 10:08 AM   #2
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I have a shallow U shaped factory pad that came with mine at 26" across @ the inside bottom edge.
"Chip Tank" is in Carson City Nv.
CDONA is offline   Reply With Quote
Old 03-24-2017, 10:08 AM   #3
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
head bump
I use pieces of foam pipe insulation or swim tube cut to fit. I've got them on the upper cabinet edges and the table leg, joe q in minnesnowda
joqin is offline   Reply With Quote
Old 03-27-2017, 07:35 AM   #4
1989 34' Excella
Here's what I came up with: A piece of pipe insulation, some aluminum bar-stock, and a few screws. Not high art, but seems to work!
Old 03-27-2017, 08:53 AM   #5
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
Another approach would be to temporarily tape a piece of barbed wire across the opening. You would only hit that once or twice before you learned to keep your head down!
John Woodrow is offline   Reply With Quote
Old 03-27-2017, 10:36 AM   #6
Boxite's Avatar
2008 22' Sport
Airstream actually installs a closed-cell foam head bumper in that location and likely so does other RV mfr's.
I also had a need to cushion a cabinet in a rent-house we own and this proved useful from Lowe's, although also sold at Target. It's a medium-firm, cushioney foam. Applies with double-stick tape. (In fact, I see you're in Austin and I have a few feet left-over. I'll be in Westlake later today if you want to meet me, You can have it. gahorn146ys (at) hotmail) (but don't knock yourself out... LOL... it's available locally)
http://www.target.com/p/kidkushion-1...B&gclsrc=aw.ds
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 03-27-2017, 11:27 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Mine has a pad above the door from the factory.
After hitting my head a couple of times I learned to duck when exiting.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door jamb too wide after shell off. 195Pilot Repairing/Replacing Floor &/or Frame 22 11-17-2012 11:47 PM
door jamb 1Lucille Windows, Doors, Locks & Vents 1 04-21-2012 12:46 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
1968 Tradewind door jamb is cracked KeithC Doors & Locks 0 07-26-2008 10:01 PM
