04-10-2018, 08:19 AM
2015 30' FB FC Bunk
Point Pleasant
, New Jersey
Door issues. Locks by itself and deadbolt not smooth
We have a 30ft FC Bunk and have a problem with the door handle locking when simply closing the door. We keep a set of keys accessible because of this.
Anyone else have this problem?
As for the deadbolt the problem has been it’s constantly out of adjustment. Very hard to turn to lock (break a key type of resistance) and have to push on door and turn lock to have deadbolt engage.
04-10-2018, 11:58 PM
2007 22' International CCD
Corona
There was a plastic friction washer retrofit available to fix that. Search around a bit for details and source of parts
04-11-2018, 02:00 AM
2021 25' Globetrotter
Jamestown
, Rhode Island
I believe that all modern Airstreams suffer from this to some degree.
I can tweak the clamping pressure on the locking arm by tightening the inner handle/plate screws to make the problem go away for the most part. Ours has the plastic friction washer.
I find that there is a fine balance between too tight, where locking the handle (not the dead bolt) is too dificult and too loose, where it can lock by itself when simply closing the door.
A little lube goes a long way to making things smooth...
Bruce
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
04-11-2018, 04:57 AM
Jamestown
, Rhode Island
By the way, tightening the handle/plate only impacts the issue of the door locking itself. The deadbolt issue sounds like a fairly serious door adjustment issue. Lube might help here but I am thinking that something else may be needed. Perhaps a trip to Colonial?
Bruce
04-11-2018, 05:09 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
We had a similar problem with the deadbolt after accidentally attempting to the door with it extended. This caused the deadbolt to jump out of the track.
Looking at the deadbolt, with the door open, I was able to move it back into it's track (towards the inside of the door) with just finger pressure. It has worked perfectly ever since.
Ray B.
04-11-2018, 05:38 AM
2014 25' Flying Cloud
Cuddebackville
, New York
I just disabled the door lock by filling the slot where the lever travels with a piece of foam. We just use the deadbolt to lock the trailer.
2019 Ford Expedition Platinum
04-11-2018, 06:44 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We had the self-locking issue on our 2005 Safari. We got an aftermarket little felt washer that went on the inside latch for the door lock. We never had the problem again. When we took delivery of our 2015 Flying cloud, it already had one of these felt washers in place.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
04-11-2018, 08:26 AM
2002 30' Classic S/O
Fleming Island
Brian
Brian,
Inland Andy provided those washers if you sent him a SASE, but I never ordered one. Since he is no longer with Inland, I presume that option is no longer available. Did you get yours from him or elsewhere? Is there a thread that describes the washer and its installation?
Al
04-11-2018, 09:33 AM
2018 30' Classic
Fresno
I had the same problem with my 2009 Flying Cloud Took to dealer and they shimmed the hinges, thereby realigning the door. The only problem is that the shims are horseshoe washers that tend to work themselves out again. Keep an eye on them and you are good to go
04-11-2018, 05:55 PM
2017 22' Sport
Gatineau
, Quebec
Similar problems with our 2017. Amazingly all fixed by simply applying silicone lubricant!
COURANT D'AIR
04-12-2018, 10:27 AM
PSU1981
2015 27' Flying Cloud
Conroe
Deadbolt out of alignment
Our 2015 FC deadbolt pin is out of alignment due to me closing the door while the pin was extended. Think that caused something to break that directed the pin to stay centered. Not sure how this can be fixed?
Glenn
04-12-2018, 10:46 AM
Niagara-on-the-Lake
, ON Canada
Glenn
Check my post #5 above. Simple fix for me.
Ray B.
04-12-2018, 03:48 PM
PSU1981
Conroe
Adventure - yeah I’ve tried that - mine doesn’t have a track
04-12-2018, 06:03 PM
2018 23' Flying Cloud
Dungville next to Donkeytown
, Alabama
Did the same thing and had to have an entirely new lock put on. The factory just removed and replaced.
~Joanna
You had me down as a damsel?
Darling, I'm the wolf.
04-16-2018, 07:13 PM
2015 30' FB FC Bunk
Point Pleasant
, New Jersey
Thanks for all of your comments. All I can tell you is it’s driving me nuts.
And I will start small and replace lock if need be.
06-05-2018, 07:36 AM
2004 26' Land Yacht Gas 26
Thibodaux
, Louisiana
Brian
Where did you install the felt washer? Behind the red lever?
06-16-2018, 01:00 PM
Loveland
Yes Andy is gone but you can still get the anti lock kit free
