10-11-2014, 09:52 AM
2002 30' Classic S/O
Fleming Island
Door Hinge Pins
My entry door hinge pins were backed out about 3/8 inch when I bought the trailer. After about 1000 miles, the top one has backed out again. I don't see any way to drive the pins out from below so I assume they are supposed to be permant and 13 years of use has loosened them a little.
I'm thinking of putting a little loc-tite on them when i drive them back in. Any reason not to do this or better solution out there?
10-11-2014, 11:16 AM
"Tinbad ... the Trailer"
1965 26' Overlander
Ferndale
The pin's are made fast by 4 deforming punches top and bottom of the pin...thus securing it within the body of the part of the hinge attached to the trailer.
Questions are:
Does your door "fit" properly in the frame and "close" snugly...
with out wobble? If so good....re-punch. Loctite may work but not for long.
Are the pins worn enough in the body of the hinge to cause any play?
If so...not so good....replace pins and plastic bushings.
As your hinge pins are loose already the hard part is already done for you
and you may (possibly) be able to remove the door to facilitate this task.
Removing the part of the hinge attached to the trailer is NOT easy and requires
cutting into the interior panel to access the nuts.
The pins may be replaced with long bolts and acorn nut but won't look as good
or smooth.
Keep all exterior hinges and moving parts lubricated to ensure long life.
Good luck
10-11-2014, 11:44 AM
2012 25' Flying Cloud
Battle Lake
Or go to Airstream dealer and get the newer style hinge ins with a slot for a split ring that holds them.
Doug and Cheryl
10-11-2014, 11:49 AM
Fleming Island
Del,
Thanks. Did you mean punch marks on the top and bottom casting? I don't think the bottom end of my castings are drilled through. I can punch the top. Punch marks on the top of both castings would keep the pins from coming out.
Everything fits good and it takes a good whack to drive the pins in, but they probably do need oiling.
Al
10-11-2014, 11:51 AM
Fleming Island
Just saw Doug's reply. Thanks. Another good option.
Al
10-11-2014, 07:29 PM
1998 30' Excella 1000
Livingston
Al & Missy, I dealt with the rising hinge pin issue for almost 10 years by knocking it back in at every stop. Two years ago I got Centramatic wheel balancers. The pins haven't moved since. Coincidence.... maybe?
10-11-2014, 07:50 PM
1999 34' Excella
Hillsboro
Yup... Strange similarity... Centramatics also and I also peened as mentioned. So hard to know..for certain.
Peace and Blessings..
Channing
WBCCI# 30676
10-11-2014, 07:57 PM
Retired.
, At Large
You can always use Terry's 30 cent hinge pin repair.
Drill a #30 hole through the hinge and pin from front toward the back, and partway through the back side of the hinge and tap a 1/8"x1/2" roll pin into the hole. Put a dab of aluminum color Parrbond over the end of the roll pin to keep it from rusting. The roll pin costs about 30 cents.
I have demonstrated this at the last two Alumapaloozas. So far, not a single one has backed out again after this repair.
04-14-2015, 06:47 PM
1997 30' Excella
Corpus Christi
Our door bottom hinge is loose
Will this method work for our problem?
04-14-2015, 06:54 PM
1997 30' Excella
Corpus Christi
What are centramatics?
Our bottom hinge is loose. Bwoodtx looked at it. He recommended drilling thru inside
04-14-2015, 07:15 PM
Oswego
This permanently fixed mine. Only one was backing out, so the other one is in my spare parts kit.
-Rich-
04-14-2015, 07:31 PM
Fleming Island
Centramatics did not fix mine. Going to try the punch route.
Al
04-18-2015, 11:04 AM
1997 30' Excella
Corpus Christi
At the hinge not door
04-18-2015, 11:07 AM
1997 30' Excella
Corpus Christi
The 1/8" is diameter? 1/2" is length?
What is parrbond?
04-18-2015, 01:32 PM
Fleming Island
Centramatics are...
Dynamic balancer for wheels. Cut down on vibration and tire wear, at least per the advertising. I got a set and the trailer seems to ride smoother but it didn't solve my hing pin problem.
Al
04-21-2015, 08:24 AM
2006 28' Classic
1998 19' Bambi
livingston
I tried lock tight it did not work
