Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 10-11-2014, 09:52 AM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Door Hinge Pins
My entry door hinge pins were backed out about 3/8 inch when I bought the trailer. After about 1000 miles, the top one has backed out again. I don't see any way to drive the pins out from below so I assume they are supposed to be permant and 13 years of use has loosened them a little.
I'm thinking of putting a little loc-tite on them when i drive them back in. Any reason not to do this or better solution out there?
Old 10-11-2014, 11:16 AM   #2
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
The pin's are made fast by 4 deforming punches top and bottom of the pin...thus securing it within the body of the part of the hinge attached to the trailer.
Questions are:
Does your door "fit" properly in the frame and "close" snugly...
with out wobble? If so good....re-punch. Loctite may work but not for long.
Are the pins worn enough in the body of the hinge to cause any play?
If so...not so good....replace pins and plastic bushings.
As your hinge pins are loose already the hard part is already done for you
and you may (possibly) be able to remove the door to facilitate this task.
Removing the part of the hinge attached to the trailer is NOT easy and requires
cutting into the interior panel to access the nuts.
The pins may be replaced with long bolts and acorn nut but won't look as good
or smooth.
Keep all exterior hinges and moving parts lubricated to ensure long life.
Good luck
Del Gurney is offline   Reply With Quote
Old 10-11-2014, 11:44 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Or go to Airstream dealer and get the newer style hinge ins with a slot for a split ring that holds them.
Doug and Cheryl
Old 10-11-2014, 11:49 AM   #4
Del,
Thanks. Did you mean punch marks on the top and bottom casting? I don't think the bottom end of my castings are drilled through. I can punch the top. Punch marks on the top of both castings would keep the pins from coming out.
Everything fits good and it takes a good whack to drive the pins in, but they probably do need oiling.
Al
Old 10-11-2014, 11:51 AM   #5
Just saw Doug's reply. Thanks. Another good option.
Al
Old 10-11-2014, 07:29 PM   #6
1998 30' Excella 1000
Livingston , Texas
Al & Missy, I dealt with the rising hinge pin issue for almost 10 years by knocking it back in at every stop. Two years ago I got Centramatic wheel balancers. The pins haven't moved since. Coincidence.... maybe?
Siegmann is offline   Reply With Quote
Old 10-11-2014, 07:50 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup... Strange similarity... Centramatics also and I also peened as mentioned. So hard to know..for certain.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-11-2014, 07:57 PM   #8
Retired.
. , At Large
You can always use Terry's 30 cent hinge pin repair.
Drill a #30 hole through the hinge and pin from front toward the back, and partway through the back side of the hinge and tap a 1/8"x1/2" roll pin into the hole. Put a dab of aluminum color Parrbond over the end of the roll pin to keep it from rusting. The roll pin costs about 30 cents.
I have demonstrated this at the last two Alumapaloozas. So far, not a single one has backed out again after this repair.
Old 04-14-2015, 06:47 PM   #9
1997 30' Excella
Corpus Christi , Texas
Our door bottom hinge is loose
Will this method work for our problem?
Knudsvig is offline   Reply With Quote
Old 04-14-2015, 06:54 PM   #10
1997 30' Excella
What are centramatics?
Our bottom hinge is loose. Bwoodtx looked at it. He recommended drilling thru inside
Old 04-14-2015, 07:15 PM   #11
dznf0g's Avatar
Oswego , Illinois
This permanently fixed mine. Only one was backing out, so the other one is in my spare parts kit.
-Rich-
Old 04-14-2015, 07:31 PM   #12
Centramatics did not fix mine. Going to try the punch route.
Al
Old 04-14-2015, 08:57 PM   #13
Livingston , Texas
Knudsvig, is the hinge loose at the door frame, or on the door? If the former, see my earlier post:
http://www.airforums.com/forums/f453...ge-122387.html
Old 04-18-2015, 11:04 AM   #14
1997 30' Excella
At the hinge not door
Old 04-18-2015, 11:07 AM   #15
1997 30' Excella
The 1/8" is diameter? 1/2" is length?
What is parrbond?
Old 04-18-2015, 01:32 PM   #16
Centramatics are...
Dynamic balancer for wheels. Cut down on vibration and tire wear, at least per the advertising. I got a set and the trailer seems to ride smoother but it didn't solve my hing pin problem.
Al
Old 04-21-2015, 08:24 AM   #17
2006 28' Classic
1998 19' Bambi
livingston , Texas
I tried lock tight it did not work
bike 2 eat is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Main Door Pins for 64 GT AlumiDillow 1960 - 1964 Globetrotter 2 07-08-2014 10:08 PM
Door Hinge Pins on 79 Excella Dano57 Doors & Locks 1 07-24-2006 07:35 PM
Cleco pins eubank Ribs, Skins & Rivets 8 02-23-2006 12:14 AM
toilet seat hinge pins? JohnGalt48 Sinks, Showers & Toilets 1 06-28-2004 11:05 AM
