Old 04-18-2015, 11:07 AM   #15
1997 30' Excella
Corpus Christi , Texas
Originally Posted by overlander63 View Post
You can always use Terry's 30 cent hinge pin repair.
Drill a #30 hole through the hinge and pin from front toward the back, and partway through the back side of the hinge and tap a 1/8"x1/2" roll pin into the hole. Put a dab of aluminum color Parrbond over the end of the roll pin to keep it from rusting. The roll pin costs about 30 cents.
I have demonstrated this at the last two Alumapaloozas. So far, not a single one has backed out again after this repair.
The 1/8" is diameter? 1/2" is length?
What is parrbond?
Knudsvig is offline   Reply With Quote
Old 04-18-2015, 01:32 PM   #16
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Centramatics are...
Originally Posted by Knudsvig View Post
Our bottom hinge is loose. Bwoodtx looked at it. He recommended drilling thru inside
Dynamic balancer for wheels. Cut down on vibration and tire wear, at least per the advertising. I got a set and the trailer seems to ride smoother but it didn't solve my hing pin problem.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 04-21-2015, 08:24 AM   #17
2006 28' Classic
1998 19' Bambi
livingston , Texas
I tried lock tight it did not work
bike 2 eat is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Main Door Pins for 64 GT AlumiDillow 1960 - 1964 Globetrotter 2 07-08-2014 10:08 PM
Door Hinge Pins on 79 Excella Dano57 Doors & Locks 1 07-24-2006 07:35 PM
Cleco pins eubank Ribs, Skins & Rivets 8 02-23-2006 12:14 AM
toilet seat hinge pins? JohnGalt48 Sinks, Showers & Toilets 1 06-28-2004 11:05 AM
