Old 01-11-2014, 05:38 PM   #1
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Door Hinge Pin loose
The upper hinge pin on the main entry door is constantly "creeping" up out of the hinge. How do I stop it from coming out and causing a big mess?
Living life on the Road
deauxrite is offline   Reply With Quote
Old 01-11-2014, 05:50 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Is there any way to use safety wire to secure it?
Since my unit is on the line assembly 210 miles from here, I can't go look easily, but could one put a set screw in the housing to lock against that pin?
Old 01-11-2014, 05:50 PM   #3
1981 31' Excella II
New Market , Alabama
Peen the end of it with a center punch.
Perry
Old 01-11-2014, 06:10 PM   #4
deauxrite's Avatar
Peen
Perry
Thanks for the reply.
The hinge appears to have been peened around the pin. Should I peen the area that has already been peened or the pin itself?
Old 01-11-2014, 06:51 PM   #5
deauxrite's Avatar
Wire
I may have to try the set screw..I don't think that it can be wired..maybe short term to get it someplace where I can really work on it.
Old 01-11-2014, 06:57 PM   #6
1981 31' Excella II
A set screw can work but you need to remove the pin and get a bottom tap and a set screw.
If you peen it you need to mash the aluminum into the steel pin. Works better when both materials are the same.
You might also be able to drill through hinge and pin and install a roll pin. It depends on how good of a machinist you are.
Perry
Old 01-11-2014, 08:06 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The last few years Airstream has installed a slotted pin and snap ring on all new trailers to hold the pin securely. These are direct replacements and available from Airstream for your trailer.
Doug and Cheryl
Old 01-11-2014, 08:15 PM   #8
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The ten cent solution is to drill a #30 hole horizontally into the top part of the hinge, through the mount, front to back, and tap a 1/8"x1/2" roll pin into the hole with a small hammer. It'll take a minute and a half, and will never work up and out of the hinge again. It is the ten cent solution because that is what a roll pin that size usually costs.
Old 01-11-2014, 09:52 PM   #9
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
We had the same problem, tried Locktite and it didn't work. We ended up having the Airstream dealer replace the pin with the new version the last time we had it in for service. We kept having to beat it back in place every time we stopped. Hope the new pin stays in place.
kswelsh is offline   Reply With Quote
Old 01-11-2014, 11:24 PM   #10
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
[QUOTE=overlander63;1402415]The ten cent solution is to drill a #30 hole horizontally into the top part of the hinge, through the mount, front to back, and tap a 1/8"x1/2" roll pin into the hole with a small hammer.
Worked for me ....
goshawks00 is offline   Reply With Quote
Old 01-12-2014, 12:52 AM   #11
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
My 2010 had that problem and the dealer fixed it with a BFH and a center punch. It hasn't been a problem on the new one.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 01-12-2014, 06:37 AM   #12
deauxrite's Avatar
I am on the way to the nearest Big Box Hardware store for a drill bit and a pin.. I will post my results in a day or two. Thanks for all of the replies!
Old 01-12-2014, 06:43 AM   #13
dznf0g's Avatar
Oswego , Illinois
I replaced with a pin kit like Doug mentions in post #7 through AS dealer.
-Rich-
Old 01-14-2014, 07:52 PM   #14
deauxrite's Avatar
Fixed
This is the solution that I used and it is working fine..though not for the faint of heart when you start drilling holes in places that do not have holes. The material is much harder than I expected, but a new drill bit took care of that. The roll pin fit is very snug and the hinge pin is now secured.
Thanks all for the input and the expertise.
