Old 01-26-2013, 01:42 PM   #1
1971 31' Sovereign
Southern Pines , North Carolina
Door Desperation
Our airstream door requires having to smash yourself into the door like a pro football player while turning the lock for it to lock or unlock properly. It came with an after market lock that is not flush with the door it sticks out. If we remove this lock there is a gaping hole in the door where the lock is meant to be. We have no keys to the original lock and I think it's likely not functional. What's the best solution here?
GHFdaja87 is offline   Reply With Quote
Old 01-26-2013, 01:43 PM   #2
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
Get a whole new airstream? You're gonna anyway....
Protohyp is offline   Reply With Quote
Old 01-26-2013, 03:45 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Your profile says, "Currently looking" so we don't know what make or model your Airstream is. But if it's not vintage, you may be able to order a new lock, with keys, direct from Airstream, or through your nearest Airstream dealer.
Failing that, going along with the lock on the door should be a strike plate on the doorframe that engages the bolt that slides in and out of the lock when you turn the key. Your problem might be solved by adjusting the strike plate to align it properly with the lock's bolt.
Cats and ultraleather Airstream upholstery don't mix!
Old 01-26-2013, 04:05 PM   #4
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
you are not too far from Out-of-Doors Mart in NC and they have a guy that specializes in fixing AS locks ..... you could send him the works .... talk to him in advance
Orlop is offline   Reply With Quote
Old 01-27-2013, 08:53 AM   #5
1971 31' Sovereign
We have a vintage 1971 Sovereign. Sorry, I thought it was listed on my profile but I guess not.
