Old 10-14-2016, 06:58 PM   #1
1964 22' Safari
Naples , New York
Smile closing windows tightly
. Found a way to close windows tightly on 1964 Globetrotter. With only cranks it is hard to close them tightly with out damaging the crank gear.
Solution: Open the window widely. Remove the two nylon filler guides in the tracks. Slide a 3/16" nut into the track and down to the bottom on each side. Take a 2" x3/16" screw eye. Place a large fender washer on it and push the end of the screw eye through the corner of the screen and into the nut in the track. Turning the screw eye pulls the window in tightly. It takes 20 minutes per window.
lletteney is offline   Reply With Quote
Oven door doesn't shut tightly karenjude Stoves, Ovens & Microwaves 1 03-19-2016 09:24 PM
1994 Excella Entry Door Not Fitting Tightly Carroe Doors & Locks 12 12-18-2015 09:16 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
Steps Opening And Closing For No Reason wb13798 Mechanics Corner - Engines, Transmission & More... 22 07-15-2005 06:06 PM
Hard closing door on 1968 rluhr 1966-68 Caravel 26 04-02-2004 05:17 PM
