Join Airstream Forums Today
Old 10-06-2011, 09:14 AM   #1
1969 21' Globetrotter
1973 25' Tradewind
Easley , South Carolina
Can you replace Keller Door lock on a 73 Tradewind with a Bargman L-400?
Does anybody have experience with replacing the Keeler door lock on a 73 or similar Airstream with a Bargman L-400 or other door lock? Maybe someone has some suggestions.
Rick
montanablue is offline   Reply With Quote
Old 10-06-2011, 10:34 AM   #2
Rick
The L-400 is history.
There are Trimark locks kits available.
Also, Keeler Brass locks were not used until the 1978 models.
Andy 12.1K
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-06-2011, 01:21 PM   #3
1973 25' Tradewind
Thanks, but I do have a question. What was the stock door lock for the 73 Tradewind? I was told it was a Keeler. Are you saying that it is a Bargman L-400. I have access to a L-400. Or maybe I can get a rebuild kit for the Keeler. The chrome is coming off. I would like to bring it back to life or at least make the door look better with a new lock. Function of the old lock is not the best.
Rick
Old 10-06-2011, 01:39 PM   #4
Rick
The entrance door lock for all Airstream trailers from 1970 to 1977, used a KT lock.
If the entrance door was changed out, it could have the Keeler Brass version.
For your info, the L-400 will not work, unless you considerably modify it.
Andy Rogozinski
Inland RV Center
Corona, CA
[IMG] code is Off
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
75' Tradewind replace tanks? Breadbug Fresh Water Systems 7 03-06-2011 10:11 AM
'75 Tradewind replace tanks? Breadbug Fresh Water Systems 3 01-21-2011 11:53 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
