Old 05-07-2016, 11:37 AM   #1
From Beautiful Egg Harbor
2016 25' Flying Cloud
Egg Harbor , Wisconsin
Broken Window FC 25 Mistake & Advice
First the admission: We failed to relatch one of the large operable Windows by the settee after we were unable to get it opened. Next day underway it popped open and when discovered 99% of glass was gone. Hardware looks fine, screen ok and no other damage.
Now the help request: Has anyone out there gone through replacement process and what can you advise?
efaehw is offline   Reply With Quote
Old 05-07-2016, 12:28 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The process is almost obscenely easy.
Vacuum up all the broken glass, unscrew the two nuts holding the lift arms to the window, swivel the old hinge up and out of its track, and swivel the replacement window into place. Screw on the two nuts on the lift arms, AND MAKE SURE THE WINDOW IS LATCHED.
Old 05-07-2016, 01:22 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
You can't go to a glass shop and pick up a standard piece of glass and have it cut to fit. It is tempered safety glass which cannot be cut. It will be easiest to get a replacement glass from a dealer.
HELP! - Advice needed- Broken Jackstand & Stuck Jackfoot TikiTime On The Road... 10 07-07-2013 07:03 AM
2010 FC 28 - Advice on R&R Broken Water Drain Tap kentuvman Fresh Water Systems 9 05-15-2013 06:05 PM
30 amp 240 mistake tcrum Batteries, Univolts, Converters & Inverters 16 09-01-2011 11:05 AM
First time Airstream owner & first mistake gurrd80 Member Introductions 2 05-20-2008 10:20 PM
First time Airstream owner & 2nd mistake gurrd80 Member Introductions 1 05-20-2008 08:02 PM
