Old 05-14-2014, 12:30 PM   #1
Travelvet's Avatar
2012 27' FB Classic
Paso Robles , California
Broken Rear Window
Hi all....
I have a 2012 27' FB Classic. My middle rear window (the flat one, NOT one of the rounded ones thankfully) was shattered by an errant rock thanks to a weed whacker. I have ordered the replacement window from Airstream but am looking for advice on replacement. My preference would have been just to haul in to our nearest dealer so they could do it, but they're booked 3 weeks out for service and we're planning to go camping next weekend. The gentleman with Airstream made it sounds rather easy to actually put the window in, but I'm skeptical and would prefer to have it done right. Has anyone tackled this? Any tips? Would I be better off having someone with auto glass repair experience do it for me? Any advice is greatly appreciated.....
Thank you!
Travelvet is offline   Reply With Quote
Old 05-14-2014, 12:58 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Airstream Life has an article that outlines removing and replacing those windows.
Old 05-14-2014, 01:20 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you ordered glass and frame it should be a straight forward job.
If you are just replacing the glass in the old frame that is a different issue.
I replaced my glass with a piece of Plexy. The problem is getting the frame apart. The 2 aluminum sections are connected with a met insert that, in my case had galled to the aluminum and I had to make a jacking device to separate the sections.
2004 Excursion 4x4
Old 05-14-2014, 05:49 PM   #4
1993 21' Sovereign
There is no sash, only a hinge and the two arms.
Old 05-18-2014, 08:56 PM   #5
Originally Posted by Travelvet View Post
Hi all....
Thank you!
Replacing the flat rear window, takes less than 5 minutes.
Is easier than a "piece of cake".
Rear Marker Lights and rear window awning Lumatic Lights - Interior & Exterior 1 12-26-2012 12:07 PM
1969 Airstream Ambassador / Broken Rear Window pewalker1 Windows & Screens 0 07-05-2011 10:50 AM
Broken plastic rear light? Argosy facade on rear tomzargosy All Argosy Trailers 9 06-11-2011 10:45 PM
Broken rear shock, bent mount effischer Airstream Motorhome Forums 2 09-27-2009 09:23 AM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 08:06 PM
