Old 01-26-2015, 11:11 AM   #1
Broken front window, 1976 Tradewind
Hi, is there anyone that can coach me on changing out the front window on a 1976 Trade wind? The frame is fine, it is just the safety glass that has shattered. Also, door has a bend outward, likely from someone trying to break in.I am thinking of heating the area with a torch and wedging it back into shape. Any and all ideas are much appreciated.Thank you
nu2argosy is offline   Reply With Quote
Old 01-26-2015, 11:58 AM   #2
Kevin245's Avatar
Originally Posted by nu2argosy View Post
..I am thinking of heating the area with a torch and wedging it back into shape. Any and all ideas are much appreciated.Thank you
I can't help you with the window, but I strongly caution against using any torch for the purpose of straightening aluminum. Aluminum does not behave like steel (turning orange/red) and will simply vanish before your eyes if too much heat is applied. Heat can have other affects on the material depending on the material grade and temper.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 02-10-2015, 05:47 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
The window is replaced as a unit frame and all .
Inland RV Center - The Nations Leading Expert in Airstream Innovations has them listed at $195 they also list the stone guard for $385
Airstream Supply has the window unit for $140
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
1972 Tradewind Front Window tesstoaster Windows & Screens 8 08-07-2013 09:45 PM
1976 ambassador front top window blinds. Sam 7 Upholstery, Blinds, Walls & Interior Finishes 0 06-03-2013 08:57 PM
'69 Tradewind broken curved roadside window-help please da_lizard Windows, Doors, Locks & Vents 3 09-21-2012 05:50 AM
Broken curved front window tommybb Windows, Doors, Locks & Vents 2 09-24-2011 09:06 PM
Broken front right curved window RREGESTER Windows & Screens 1 02-09-2003 09:05 PM
