Old 03-29-2012, 10:20 AM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Bargman L-100. Now what?
I have the L-100 on my Cayo. It's in working condition but is clearly worn and since I'm planning on camping fairly extensively I don't want it to fail especially if that results in a lock-in or lock-out.
Replacements are still available but are costly. Reports are the quality, which was never especially high on these, is lower than it was originally due to deterioration of the tooling towards the end of the production run.
Any advice? Particularly:
- If I keep this are there particular parts I can clean, inspect, lubricate, adjust, or replace that will prevent a failure?
- Is replacing it with another L-100 likely to provide a satisfactory solution?
- If I replace it with something else, what locks are the best candidates to consider? How extensive are the modifications to the door and strike?
Old 03-29-2012, 11:43 AM   #2
salzburg , salzburg
I am in the position of looking into this at the moment, from what i can make out it is the bolt that needs to be extended and then it should be fairly straight forward, i certainly won't give out the ridiculous money some of the dealers want for an extended bolt when a $50 lock suddenly becomes a $280 lock i am sure a machine shop can make alot of things for $230!
mrgreen is offline   Reply With Quote
Old 03-29-2012, 12:09 PM   #3
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
On my trailer the bolt was in good shape but the other parts needed replacing. I bought the cheaper of the two locksets and combined the two. Works great!
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 03-29-2012, 12:13 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Andy and Inland recently posted about a new replacement for the L-100 and L-200 locks. See http://www.airforums.com/forums/f206...ock-87671.html. Looks worth considering. I know I have not been impressed with the L-100s. I've replaced the one on my Trade Wind twice now.
The ones in his post are for the "special" version that fits Airstream. I assume that there would be a version that has the regular length bolt if that's what you need for your Cayo.
Vaughan
Old 01-31-2014, 07:50 AM   #5
Jim & Mitzi's Avatar
1987 32' Excella
1990 29' Land Yacht
Americus , Alsrural Bristol Tn.
I have a 68 ambassador. Bargman l200. = long bolt . Had to turn knob while talking nicely to it to eventually get the bolt to back out of the door jamb. I spent "several" hours dis and re assembling and adding a few homemade parts . New works great everytime. It always was ok from inside. The shaft in the knob was jumping out and wearing out 1 if the inner moving parts. Patience paid off....
Jim & Mitzi is offline   Reply With Quote
Old 01-31-2014, 09:35 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
I ultimately did find a NOS overhaul kit that included the outer knob and trim, and the mechanism. It's installed now and works OK. I ended up using a little loctite on the screw that holds the inside knob in place since it was working its way loose. I think that was actually much of my problem.
What's playing on your 8-track... Mexray Audio, Video & TV 17 04-23-2012 07:06 PM
What's your favorite brand rivet gun? REDSLED88 General Repair Forum 19 04-09-2012 07:18 AM
What can I expect to pay for a complete Battery system ? mountainsun Batteries, Univolts, Converters & Inverters 12 03-31-2012 10:08 PM
What Kind of Rivet Do I need? Why Olympic rivets? Kyle-King Ribs, Skins & Rivets 10 03-27-2012 09:47 PM
