Old 04-15-2016, 02:30 PM   #1
1969 27' Overlander
Leadville , Colorado
Bargman L 100-6 repair
Looking for a locksmith who can give me a price and who can repair my 1969 Overlander entry lock set. I do not have the key and the exterior handle fell off. I have removed the lock set.
DJHorning is offline   Reply With Quote
Old 04-15-2016, 03:26 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The keying is the easy part. The hard part will be finding the handle and a project you should work on first. Try Vintage Trailer Supply and any salvage yard that may have older Airstream parts maybe Sonny at Camper Repair in Montavallo Al.
2004 Excursion 4x4
Old 04-15-2016, 07:09 PM   #3
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
I have plenty of used parts of the Bargman L 100 and L 200 locks. I can even help you with a new or used one as a replacement if you like. You might just need a new handle but beware there might be other issues as well. I have some outside handles and can help you rebuild it if you choose. Send me a private message and I will be glad to help.
Rick
montanablue is offline   Reply With Quote
Old 04-16-2016, 07:03 PM   #4
1969 27' Overlander
Hi Rick, I'm glad to here you have some L 100-6 parts. It looked like a piece at the end of the exterior handle had sheared off perhaps made from cast white metal. I recently purchased this airstream. With help I have now have all the systems working, removed all doors reglued all the failed laminate touched them up the 3 coats of lacquer. The lock had me stymied, if you have the parts and the know how I would really like to keep it like the original. Do you have an idea of what it might take cost wise? Thanks so much. I'm in Leadville Colorado, I could ship the handle to you. Email: horningdj@gmail.com
Dave
Old 04-17-2016, 12:08 PM   #5
1967 26' Overlander
Spartanburg , South Carolina
Rick
Hi Rick...Wish I knew you when my L100-6 sheared the actuator tang on the bolt finger that slides the bolt back from the inside. I and my 95 lb dog got locked in so I went out the rear window and thankfully, was able to open the door from the outside. At the time, no amount of internet search or phone calls produced a replacement. I removed the lock assembly, tied the door shut to get home and had a local machine shop make a new bolt from mild steel. I keep it coated with grease to prevent rust and so far it is ok. I may need your advice later so will keep you in mind if you don't mind a direct contact....Jake.....jacobbutts@gmail.com
Jacob D is offline   Reply With Quote
Bargman L-100 Pics - need parts JoePfznik Doors & Locks 42 02-12-2018 07:57 AM
Bargman L-100. Now what? Jammer Windows, Doors, Locks & Vents 5 01-31-2014 09:35 AM
Door knob: Bargman L-100 or L-200 - 1964? joedombroski 1960 - 1964 Globetrotter 0 07-25-2013 08:09 AM
L-100 Bargman Doorlock/Need pic Maeffy Doors & Locks 3 09-09-2011 04:23 AM
'62 globetrotter - bargman L-100 doesn't fit - help? jrsygrl Doors & Locks 4 02-26-2011 03:25 PM
