Join Airstream Forums Today
Old 01-09-2012, 05:32 PM   #1
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Bargman H20-2 install pics?
Im mounting a Bargman H-20-2 handle in my trailer door. Does anyone have a pic of how it was installed in a factory install. I can dream up a way but I prefer not to complicate things. Thanks in advance
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 01-09-2012, 06:26 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi BradS, VTS seems to have some good picks and a walk through in the field notes. Take a look here. Bargman H20-2 Handle.
There are a few threads on this lock too. Bargman H20-2 - Google Search
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-10-2012, 05:15 AM   #3
BradS's Avatar
1957 26' Overlander
Images: 14
Thank you Lee
What I would really like to see is a photo of the inside of the door with the handle installed. I have seen the face of the door with the handle installed, Im looking for the business end
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-28-2012, 08:54 PM   #4
BradS's Avatar
1957 26' Overlander
Images: 14
I came up with a way to mount the Bargman handle in my door. It wasn't much after I finished that Doug posted a pic of how the factory did it.The first pic is the plate I made to hold it in place, second pic is the handle installed and the last is how the factory did it.
ID:	149747   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-28-2012, 09:48 PM   #5
1958 26' Overlander
Lander , Wyoming
Thumbs up
Brad, I rebuilt 2 of these locks. I used por15 on the 2 steel braces and recreated the wood insert ( a much better looking piece than original) and coated it with marine epoxy to extend its lifespan. I like your solution. Cleaner, stronger and will not degrade. Wish I had thought of something similar. However, mine are done and work flawlessly. Ed
n2batr is offline   Reply With Quote
Old 01-31-2012, 06:23 PM   #6
desertair27's Avatar
1977 31' Sovereign
El Paso , Texas
Yours looks great and what I would think the factory would do, the other looks like a caveman made!Keep up the good work and thanks for sharing.
desertair27 is online now   Reply With Quote
Old 02-18-2012, 06:35 AM   #7
cuyeda's Avatar
Long Beach , California
Bargman H-20-2 lockset key
Came across this thread, and looking for a lockset cylinder for the Bargman H-20-2. I have this lock, but need an actual key. Anyone know of a replacement source?
cuyeda is offline   Reply With Quote
Old 03-01-2012, 03:17 PM   #8
1987 31' Excella
Lake City , Florida
You can get parts at Inland rv.com
rb
robertbeavers is offline   Reply With Quote
Old 03-02-2012, 12:32 PM   #9
cuyeda's Avatar
Went to Inland RV showed a picture of the lock, and they do not have replacement parts. FYI
I did source a used lockset from a Craig's list ad, but they want $350. Will try a locksmith to see how far I get with that option.
Old 03-02-2012, 12:36 PM   #10
BradS's Avatar
1957 26' Overlander
Images: 14
i didnt think they would. This lock has been out of production for a real long time. I have herd rumor that the lock cylinder is from an old ford product. Something like a 1938. The cylinder I have is still in working order although I wouldnt mind finding a spare if you locate a good source
WBCCI 10289
TAC MN-69
AIR 11240
[IMG] code is Off
Hi from Wiarton ON, looking at our first AS on Saturday-'66 Safari+ (Pics) Shiny Dreams Member Introductions 30 09-24-2011 09:51 PM
Bargman H20 copycat carl Doors & Locks 3 09-01-2011 08:59 PM
4CU 004 : Spring break at the lake silverback WBCCI Rallies & Events 68 04-19-2011 08:55 PM
Onan install – ’05 30’ Classic GetOutDoors Generators & Solar Power 10 04-18-2011 09:11 PM
