Old 06-21-2013, 06:05 AM   #1
1976 31' Sovereign
Back window in 76 Sovereign won't close!
Hi guys!
My back window in my Airstream won't close unless someone on the outside is pushing while someone on the inside latches the locks! I've sprayed some wd40 on the hinges but it didn't seem to do much good! Any other suggestions? Do I need to take out the window? I'm in the south and I don't want the 100 degree temperature coming in!
Thanks so much for your help!
Melissa
wallybgirl is offline   Reply With Quote
Old 07-28-2013, 05:41 PM   #2
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
I have a similar problem with my 1975, I found the weather stripping had bulged out, carved it down a bit and window fits much better. Actually I should have replaced the weather stripping..(:
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
screens, sovereign, repair, window
