Old 08-17-2014, 04:25 PM   #1
2013 27' Flying Cloud
Bonita Springs , Florida
Awning Roller
We are new Airstream owners and are preparing it for a long trip. In Rich Luhr's Newbie Book he recommends having a roller on the door to protect the awning. With rounded door corners and a gutter just above the door how does one mount such a roller? Help please in Florida. We are heading to BC Canada in less then a week.
Flyfsfrank is offline   Reply With Quote
Old 08-17-2014, 04:36 PM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I'd call Zip Dee or Airstream but it looks like you use rivets or screws to mount it. We don't have one and if the awning is all the way up you won't need it. I read on here somewhere that Airstream must have a ton of these because they come with every awning they ship. I'm not sure you really need it.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 08-17-2014, 05:27 PM   #3
1976 31' Sovereign
Oswego , Illinois
I balked when zip-dee started to put roller on my AS but let them go ahead with installation was best thing I did when they showed me that top of door would rub on awning even if was up all way. Roller goes on front of door handle side, pop rivets on or olympic if you have them, but any rv repair shop or dealer should be able to install, as some other trailers use them to. if pop rivet on make sure to seal them.
Old 08-17-2014, 06:09 PM   #4
1976 31' Sovereign
Oswego , Illinois
Follow up olympic rivets will not work as cannot get shaver on head. To install top of roller bracket goes up to trim at top of door then slightly past strait top of door into curve on handle side, if installed on strait part of top of door will be to high. PS a ounce of prevention better than cure, so why take chance of tearing or rubbing on awning with out roller, also if 1 corner is dropped in rain door will rub. Should not take ten min. to install.
Old 09-03-2014, 06:41 PM   #5
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Go without the roller and see if you need it. It looks kind of klunky installed, and I opted not to do it. With my awning fully up on the door side and down one notch on the other end for rain drainage, the door never rubs the awning. When I put the awning in "caravan" position, short extension, the door rubs the awning a little, just be gentle when you open the door. Six years of use on our old 2007 showed no awning wear without the roller.
Randy
Randy and Pat Godfrey
Region 3 1st VP, Florida Airstream Club (027)
WBAC# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
New roller tube for old Carefree awning maccamper Awnings 7 06-09-2009 05:49 PM
Awning roller on International 25 ft Senshi 1980-1984 International 5 11-07-2008 06:25 PM
Bent awning roller repair gparker Awnings 12 03-09-2007 02:28 AM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
